    Dismiss Notice
    Dismiss Notice
1003.3.3 Horizontal Projections 2015 IBC
Discussion in 'Accessibility' started by cda, May 1, 2018.
  1. cda
    cda Sawhorse
    Oct 19, 2009
    14,453
    796
    So looking at fire hose valves exposed in corridors.
    Not up on projections, but appears the set up attached, violates 1003.3.3??????????
    Objects with leading edges more than 27 inches (685 mm) and not more than 80 inches (2030 mm) above the floor shall not project horizontally more than 4 inches (102 mm) into the circulation path.
    Exception: Handrails are permitted to protrude 41/2 inches (114 mm) from the wall.
    • hV.pdf
      File size:
      39.7 KB
      16
  2. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    1,208
    287
    Is this tucked into a corner or is it somewhere along the length of the corridor wall? If in a corner, I would say it is not in the circulation path—if along the length of the wall, I would say that it is.
  3. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,260
    182
    concurr
  4. cda
    cda Sawhorse
    Oct 19, 2009
    14,453
    796
    Yes on a vertical corridor wall,,
    As a person would walk.
    Is circulation path defined??
    To me a person could walk against or near either side of a corridor wall.
    I looked at the commentary picture, and appears to violate that set up.
  5. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    1,208
    287
    Yes, "circulation path" is defined in Chapter 2.
  6. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,260
    182
    better yet is if the pipe was extended to the floor for cane detection.
    Pcinspector1 likes this.
  7. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    1,208
    287
    The problem with that is it could not function as a system drain. A type of bollard or other device that projects up from the floor on each side of the drain would suffice for cane detection.
  8. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,260
    182
    yes, anything will do as long as it is "fixed" in place.
  9. cda
    cda Sawhorse
    Oct 19, 2009
    14,453
    796
    CIRCULATION PATH. An exterior or interior way of passage from one place to another for pedestrians.
    So I take it,,, it includes the entire width of the corridor ???
  10. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    1,208
    287
    Yes--not just the required egress width.
  11. cda
    cda Sawhorse
    Oct 19, 2009
    14,453
    796
    So per the drawing attached in op
    Some of the hose valve and pipe is between 27 and 80 inches
    And extends past four inches
    Seem it does not comply with the section ??
    my250r11 likes this.
  12. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    1,208
    287
    No, it doesn't comply, since the leading edge, which projects out 6-1/2 inches (more than 4 inches), is at a height greater than 27 inches and is less than 80 inches.
    cda likes this.
  13. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,260
    182
    CDA, ever hit a low branch or you knee while out walking?
    Step off a curb while engrossed in your cell phone?
    Its what you don't "see" that will get you every time.
    cda likes this.
  14. cda
    cda Sawhorse
    Oct 19, 2009
    14,453
    796
    Not my area
    Just got lost in the code language vs the picture in the commentary
  15. cda
    cda Sawhorse
    Oct 19, 2009
    14,453
    796
    Ok this has come around
    And I think you have the answer,
    So if the corridor is wide enough,
    And they say sheet rock box around the pipe,,,
    Floor to ceiling, there is no more projection problem??????
  16. Yikes
    Yikes Gold Member
    Nov 2, 2009
    1,200
    98
    Doesn't need to be "floor to ceiling" box - - just needs to be "cane detection". You can essentially build a "curb" at the floor level that will provide sufficient can detection.
    for example, if you had 4" tall rubber base on the walls, then build a 4" tall curb and wrap the base around it.
Share This Page
