    Dismiss Notice
    Dismiss Notice
An average day
Discussion in 'Contractor Talk' started by ICE, Oct 13, 2011.
  1. ICE
    ICE Sawhorse
    7,260
    520
    The contractor is a Mechanical contractor (C-20). The job is a new furnace, a/c and electrical service upgrade.
    The panel is 4' 4" from the pool. The minimum requirement is 5’. There was a flush mount panel located at the same spot previously. The enclosure is mounted over a hole in the wall. I requested that a licensed Electrical contractor take out the electrical permit.
    [​IMG]
    [​IMG]
  2. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,339
    80
    Never saw a pool so close to a house. Would you make them bond the rain gutter and window frame to the pool bonding system now or only when the pool or rain gutter or window is new?
  3. ICE
    ICE Sawhorse
    7,260
    520
    It would be a hard sell to ask for bonding the windows, weep screed, and gutter after the fact. The new service panel will be relocated.
  4. ICE
    ICE Sawhorse
    7,260
    520
  5. ICE
    ICE Sawhorse
    7,260
    520
    Could somebody please tell us what is wrong here? A code section would be great.
    [​IMG]
  6. ICE
    ICE Sawhorse
    7,260
    520
    The contractor told the lady that this might be a problem. "Let's see what happens with the inspector".
    [​IMG]
    [​IMG]
  7. ICE
    ICE Sawhorse
    7,260
    520
    Same pool, different clamps.
    [​IMG]
    [​IMG]
  8. linnrg
    linnrg Sawhorse
    Mar 17, 2015
    258
    61
    #2826
    t&p to a drain
    washer to piping that does not have a trap (is that some for of a extension threaded pipe drainage?) possible undersize of a vent. Where does the condensate pump discharge to? Outlet is not GFCI.
    appliances are elevated so must be a garage. Do you require the other appliances to be elevated as well (I see gas piping so I assume gas dryer). We have had to differing opinions about that.
    rogerpa likes this.
  9. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,339
    80
    Looks like a basement to me.
    The P&T relief valve does not comply with IRC P2803.6.1:
    1. Not to be connected to drainage system
    2. Discharge through a air gap
    7. Discharge in a termination point that is readily observable
    8. Not be trapped
  10. ICE
    ICE Sawhorse
    7,260
    520
    I suppose the code would support raising a gas clothes dryer. I don't enforce it that way. I'll ask around and see what other inspectors are doing. My feeling is that I can approve what I inspect and the laundry equip is not part of that. Well heck...maybe it is....part of that I mean. I'll find out....if I don't forget. What was I talking about just now?
    Garage doors work like an explosion vent. I had a case where a father and son turned the two car garage into a spray booth. By the look of the laundry sink, I think it lasted a long time. But one day it blew up. Junior had just stepped out the man door when it went. The door flattened him and the blast knocked the walls off the footing. When they built it back I made them demo the laundry sink. They had been draining paint and who knows what for years. Funny thing is that the neighbors didn't complain and I found over-spray in a lot of spots.
  11. ICE
    ICE Sawhorse
    7,260
    520
    Some jurisdictions accept a document in lieu of inspecting smoke and CO alarms. And by the way, they are not detectors.....don't say smoke detector or Co detector. A detector isn't going to wake you up. Well anyway, I have seen a few of the documents stapled to a job card like I will inspect whatever and not need to go inside. I have said no because I detected dishonesty and found no alarms. I just wanted to use the word detected in a sentence. I would never accept a document. I've even see them with a Notary seal. It's only been a handful of times and each time there was no detectors....or alarms either.
    Today was a good example of the level of competence found in the solar industry. The guy handed me this with all the confidence in the world that I would just move on.
    [​IMG]
  12. conarb
    conarb Sawhorse
    Oct 22, 2009
    3,198
    222
    Tiger:
    So the solar contractors are giving the owners these forms telling their customers to fill them out and attach them to the permit cards to avoid liability?
  13. Ty J.
    Ty J. Active Member
    Aug 2, 2017
    101
    49
    Form looks super official as the first word is missing the first letter. Starts off well....
    Aside from the fact that this should never be accepted, the form documents a non-compliant installation - 3 floors yet only 2 alarms?
    mark handler and my250r11 like this.
  14. fatboy
    fatboy Administrator
    Oct 17, 2009
    5,366
    358
    My thoughts exactly!
    my250r11 likes this.
  15. ICE
    ICE Sawhorse
    7,260
    520
    The plan was to remove the screw to show me that the pipe is filled with water. He said that it's just a vent so a dab of glue will fix it.
    [​IMG]
  16. ICE
    ICE Sawhorse
    7,260
    520
    Now that's a rodent problem.
    [​IMG]
  17. ICE
    ICE Sawhorse
    7,260
    520
    A lot of mistakes in a small space. The worst of which was not bringing along a neutral conductor.
    [​IMG]
    [​IMG]
    The owner said that the contractor chose this spot to place the unit because there was a plumbing vent close by.
    [​IMG]
    I'm not so sure that the label behind the disconnect is all that important but the panel that it is mounted to is meant to come off for access to the innards.
    [​IMG]
    Right down to the screw for the dead front. I had to use my pliers to remove it and it never cinches up because it's a sheet metal screw in a machine screw application.
    [​IMG]
    The contractor is a large outfit. They have salespeople at Costco. An affiliation with a big box store is a red flag. As soon as the owner says that ***** or **** ***** is the contractor I know that a recent parole might have been doing the work. You know, there's training available in the penal system. Ok so I exaggerate. I doubt that many are are paroles....work release is more likely.
    It was 105° in the shade and hotter on that roof. I should have not gone up there....nope, I should have said, "The disconnect is located in the wrong spot. Move it and call for inspection".
    Next time out, when I got to the top of the ladder it should have been, "You can't use a plumbing vent for a condensate disposal. Do that over and call for inspection".
    The next time out it could have been, "That's the wrong screw for the dead front"....and on it goes.
    Perhaps that would teach them to not send inexperienced workers to do the work. But obviously I can't do that so I write a dozen stupid corrections. They can't even install a lock ring correctly.
    Yes I know that it's my job and I am paid to do this. So who am I to complain? The issue for me is the knowledge that slipshod work passes inspection in most cases. That's not because the work was done correctly. It is because the inspector didn't know or didn't look or didn't care.
    I don't make such a statement lightly. I have first hand experience. I have witnessed that many times. It is getting worse.
    If you ever find Snap-On pliers like that in the picture I'll trade too many dollars for that pliers.
    #2837 ICE, Jul 14, 2018 at 12:13 PM
  18. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    9,509
    472
    Second unit?
  19. ICE
    ICE Sawhorse
    7,260
    520
    Not sure as I didn't get that close. Of course the rules have been watered down to accommodate converted garages so if it is a second unit a permit will fix that.
  20. mark handler
    Oct 25, 2009
    9,509
    472
    2013? codes
    Spelling
    yes the forms are given to the owners. Yes there is liability.
Share This Page
