    Dismiss Notice
    Dismiss Notice
Bathroom distances
Discussion in 'Accessibility' started by tomsmith, Feb 3, 2018.
  1. tomsmith
    tomsmith Member
    Feb 3, 2018
    17
    1
    In dwelling unit, what is the typical distance required between lavatory/water closet? I would like to know the requirement for both ADA and non-ADA (the project my firm is building is based on IBC 2012).
  2. cda
    cda Sawhorse
    Oct 19, 2009
    13,339
    656
    Welcome
    Give it a few days for replies. super bowl weekend
  3. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,422
    546
    Have your firm buy an ICC/ANSI 117...You are going to need it....I believe CH 10 is dwelling units still...
  4. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    9,185
    387
    Is this a Dwelling unit under the ADA?
    Are you sure?
    Is this Government housing?
  5. tomsmith
    tomsmith Member
    Feb 3, 2018
    17
    1
    I believe Fair Housing Act
  6. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,643
    226
    If an IRC dwelling, then the plumbing chapters in the IRC provide minimum clearances (generally) for usability.
    If an IBC regulated building then the IPC has provisions for distances (generally) for usability.
    For accessibility, Chapter 11 of the IBC provides specific requirements and refers to the ANSI A-117 standard for the layout details.
    Ty J. likes this.
  7. mark handler
    Oct 25, 2009
    9,185
    387
  8. tomsmith
    tomsmith Member
    Feb 3, 2018
    17
    1
    I'm sorry- I confused the code. This is a question under ADA provision for dwelling unit, what would be the minimum required distance b/w lavatory and water closet?
  9. mark handler
    Oct 25, 2009
    9,185
    387
    What kind of "dwelling unit"?
    ADA does not cover Apartment "dwelling units".
    Maybe you should get some "professional help" with the code.
    You will not find it here because you are not giving the whole picture.
  10. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    884
    94
    ADASAD covers government dwelling units, college dormitories, hotels & motels, including extended-stay motels, all of which which are similar to apartments.
    ADASAD 604.3.2 Exception allows a lavatory to be 18" from the CL of the water closet in a residential dwelling unit. Otherwise a 5 ft. wide clear space is required at the WC.
  11. mark handler
    Oct 25, 2009
    9,185
    387
    That's why I ask......What kind of "dwelling unit"?
  12. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    1,886
    147
    See 1127A.3 of CBC for lavatories.
  13. mark handler
    Oct 25, 2009
    9,185
    387
    In CA only
  14. tomsmith
    tomsmith Member
    Feb 3, 2018
    17
    1
    I'm not sure what you mean by what type of dwelling unit, but my question is simply what is simply what distance is required in residential dwelling unit b/w lavatory and water closet.. I believe the 18" answers my question
  15. mark handler
    Oct 25, 2009
    9,185
    387
    You started out with ADA "stuff"; 18" may not be the correct number for ADA.
    What kind of dwelling unit are you dealing with and does the ADA apply to that dwelling unit?
    #15 mark handler, Feb 17, 2018 at 2:10 PM
Share This Page
