    Dismiss Notice
    Dismiss Notice
Door to accessible space under stair
Discussion in 'Residential Building Codes' started by Andrea Schoening, Apr 12, 2018.
  1. Andrea Schoening
    Andrea Schoening New Member
    Apr 12, 2018
    4
    0
    Instead of of having nothing under the platform of a U shaped stair, I decided to enclose it, creating a space with 4'-11" ceiling height. It's really just a storage space. I want to add a access door so that the client can store stuff under the stair. I get that per R302.7 the walls and ceiling need type x gyp on it but what about the access door? Does it have to be a 20 min rated fire separation door with self closing device? This seems like overkill but I can't find anything about doors that lead to the accessible space under stairs. Help please.
  2. cda
    cda Sawhorse
    Oct 19, 2009
    13,973
    742
    Welcome
    Is your office on the beach?!
  3. cda
    cda Sawhorse
    Oct 19, 2009
    13,973
    742
    Have to look at the book
    I am thinking no
  4. Francis Vineyard
    Francis Vineyard Sawhorse
    Jan 1, 2010
    2,921
    346
  5. cda
    cda Sawhorse
    Oct 19, 2009
    13,973
    742
    Does it need a door
    And if so a rated one??
  6. Andrea Schoening
    Apr 12, 2018
    4
    0
    it needs some kind of access panel/door. if the door needs to be fire rated was my question..
  7. Andrea Schoening
    Apr 12, 2018
    4
    0
    lol, I wish ;)
  8. Francis Vineyard
    Jan 1, 2010
    2,921
    346
    There's no requirement for a door.
    cda likes this.
  9. my250r11
    my250r11 Sawhorse
    Feb 16, 2015
    294
    96
    Don't forget the fire blocking in the stringers.
    Andrea Schoening likes this.
  10. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,596
    610
    If there is no door, is it really enclosed......;)? ....To answer the OP, no special requirements for that door, just the drywall.
  11. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    9,405
    448
    As stated above, nothing in the 2016 California Residential Code, requires it
    Provide one-hour fire resistive construction on walls & ceiling under the interior of stairway
    If the fire burns up the door, the framing is still protected
  12. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,238
    185
    If the stairs are set up like the photo's that Francis posted, then I believe your interior doors will work just fine.
    But if your entering from a garage side then the door would have to meet the same requirements steel or solid core wood door with closer.
    I have seen this same u-shaped stairway with a cut-down door below the platform being entered from the garage side (resident wanted to store mowers under the stairs) and I have seen an opening on the rec-room side with a cut-down door. Some do not want to loose the space and want the coat closet separate from the storage under the stairway.
  13. Andrea Schoening
    Apr 12, 2018
    4
    0
    Thank you, this makes a lot of sense
  14. Lisa Smith
    Lisa Smith New Member
    May 15, 2018
    2
    0
    Hi, I stumbled across this forum looking for information.
    I am the President of my HOA (which is in the city of SD), and we have a proposal from a homeowner in front of us to put in a closet under her stairs (just like above). There is a HOA Board member that is saying that "it is code" to drywall the storage room that is being put in and not leave it as studs. The homeowner is saying that the closet doesn't require interior drywall. They have been going back and forth for months.
    Based on what I am seeing above, it looks like it is required. I've attempted to find this in the 2016 California Residential Building Code, but can't seem to find it. Can anyone point me with a link or tell me which specific section of the code has this information so I can't print it and bring it to the meeting, and resolve this matter. I would really appreciate any help in locating the specific text so I can print it.
    Thank you for your help!
  15. Lisa Smith
    May 15, 2018
    2
    0
    Nevermind, I found it from the list above. Its been a long day.
  16. ICE
    ICE Sawhorse
    7,152
    487
    I need to be convinced about that.
  17. cda
    cda Sawhorse
    Oct 19, 2009
    13,973
    742
    Welcome !!!
  18. cda
    cda Sawhorse
    Oct 19, 2009
    13,973
    742
    Have to love hoa’s
Share This Page
