    Dismiss Notice
    Dismiss Notice
Electric service feed up foundation
Discussion in 'Residential Foundation Codes' started by Jdz, Jan 21, 2018.
  1. Jdz
    Jdz Member
    Jan 21, 2018
    5
    0
    i am trying to figure out the best way to keep the outside of a building clean and thought about running the electrical service feed up the foundation, keeping it in the wall, using a flush mount meter base. I cannot find any requirements for the thickness of the foundation if I do this and I was wondering if there are any requirements.
  2. cda
    cda Sawhorse
    Oct 19, 2009
    14,242
    781
    welcome!!!!
  3. cda
    cda Sawhorse
    Oct 19, 2009
    14,242
    781
    Not into electrical, put you might just check with your electrical utility provider first,
    To see if they allow it,
    Give the thread a day or two for replies
  4. Jdz
    Jdz Member
    Jan 21, 2018
    5
    0
    They allow it, they have drawings for it on their website. There just aren’t any numbers for foundation thickness or anything like that. I figure that will have more to do with building codes.
  5. Mark K
    Mark K Platinum Member
    May 12, 2010
    1,297
    52
    Make the foundation wider to offset the notch or hole resulting from the introduction of the conduit.
  6. north star
    north star Sawhorse
    Oct 19, 2009
    3,475
    179
    Jdz,
    Also, Welcome to The Building Codes Forum !
    Can you post a Link of those drawings, or provide the
    name of the company and maybe we can research
    their technical specs. for you ?
    Thanks !
  7. Jdz
    Jdz Member
    Jan 21, 2018
    5
    0
  8. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    931
    106
    8" block would have large enough cores to run the conduit in the block. The masons will grumble, but they can lift the blocks over the conduit to lay them.
  9. north star
    north star Sawhorse
    Oct 19, 2009
    3,475
    179
    Jdz,
    I recommend that you contact the Bldg. Official
    in the area where the residence will be constructed.
    They "should" be able to provide you with the minimum
    foundation thickness required for a residential foundation.
    Is the horizontal foundation what you are concerned with,
    or the footings, both or something else ?......What is the
    applicable Code & edition you are using ?
    If you were referring to a section of plumbing piping
    passing thru a foundation wall, then you might want to
    look at Section P2603.4, in the `15 IRC as a reference.
  10. Jdz
    Jdz Member
    Jan 21, 2018
    5
    0
    I plan on using poured concrete for the foundation, I am not a fan of stacking blocks for a foundation. Since the footings need to be 2” wider that the foundation wall, I need to know how thick to set the forms. I really don’t want to pour a 10” foundation if I can put it in a 6” foundation wall. I also don’t want the foundation cracking on me. IBC 2015 fyi
  11. Jdz
    Jdz Member
    Jan 21, 2018
    5
    0
    I think I am just going to add the 3.5” to the wall and play it safe
  12. Msradell
    Msradell Sawhorse
    Jul 23, 2011
    740
    49
    Normal concrete coverage for anything embedded is normally 2", the absolute minimum is 1.5"
Share This Page
