    Dismiss Notice
    Dismiss Notice
Floor Drains In Mech. Rooms & Other Spaces
Discussion in 'Commercial Plumbing Codes' started by north star, Mar 12, 2018.
  1. north star
    north star Sawhorse
    Oct 19, 2009
    3,504
    186
    Greetings to all !
    I am seeking input as to how your jurisdiction handles Floor Drains
    in Mechanical or Electrical Rooms.......Typically, in Restrooms
    there are Trap Primers installed.
    I have a project where the Military Bldg. owner is installing a
    high security vault, 11' x 9' sq. ft., plus a Floor Drain.
    QUESTION # 1: Do you require ALL trap seals to be protected
    from drying out [ RE: `12 IPC, Section 1002.4 ] ?
    QUESTION # 2: If you answered "No" to Question # 1, do those
    trap seals ever dry out ?
    QUESTION # 3: If you answered "Yes" to Question # 1, how are
    the trap seals protected ?
    Thanks for your input !
  2. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,701
    640
    They do dry out.....Town Hall bathrooms do it all the time....I think they have some type of
    mechanical flapper now, but trap primer more common...
    JBI likes this.
  3. north star
    north star Sawhorse
    Oct 19, 2009
    3,504
    186
    Thanks **steveray** !
    While the trap primers are [ typically ] considered to be the
    most common, ...ProVent makes one kind of a waterless Trap
    Seal.
    [​IMG]
    I am curious as to how others are addressing this Code requirement.
  4. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    728
    67
    The seal will dry out. Trap Gaurd is how we handle it.
    An old way of dealing with a floor drain that was installed as emergency only was to pour vegetable oil within but this was when workers stayed with a job for most of there career and took pride in the job & maintenance.
    #4 Keystone, Mar 12, 2018
    my250r11 likes this.
  5. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,708
    249
    While the IPC provides a few options for maintaining a water seal, at an older Town Hall I once worked in we simply told the janitor to use more water when washing the bathroom floors to insure the trap stayed full.
    north star likes this.
  6. mp25
    mp25 Registered User
    Jun 2, 2016
    47
    8
    My state plumbing code (IL) provides 3 methods (code updated in 2014):
    1. addition of vegetable oil
    2. deep seal trap (8" max) - takes longer to evaporate
    3. Automatic Trap Primer
  7. SRK_Mech
    SRK_Mech Registered User
    Dec 14, 2016
    19
    0
    I do code review for NJ, NY State and NY City:
    Question #1 then 3: Yes. Trap primers.
    I noticed that janitors are using Swiffer instead of a mop and a bucket of water. No wonder why these rooms smell so bad.
  8. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,260
    182
    Love you guys, so much knowledge shared but not always transmitted.
    Thank you
  9. Francis Vineyard
    Francis Vineyard Sawhorse
    Jan 1, 2010
    3,006
    372
    2015 IPC;
    Section 1002.4
    has been expanded to cover two additional types of trap seal protection devices and to distinguish between the different types of water-supplied trap seal protection devices.
    The latest trap seal protection device is for floor drains only and utilizes a specially designed and tested insert below the floor drain strainer plate. When water runs into the floor drain, the insert allows the water to pass and then closes to significantly reduce evaporation of the trap seal.
    1002.4.1 Trap Seal Protection. Trap seals of emergency floor drain traps and traps subject to evaporation shall be protected by one of the methods in Sections 1002.4.1.1 through 1002.4.1.4.
    1002.4.1.1 Potable Water Supplied Trap Seal Primer Valve. A potable water supplied trap seal primer valve shall supply water to the trap.
    Water supplied trap seal primer valves shall conform to ASSE 1018. The discharge pipe from the trap seal primer valve shall connect to the trap above the trap seal on the inlet side of the trap.
    1002.4.1.2 Reclaimed or Gray Water Supplied Trap Seal Primer Valve.
    A reclaimed or gray water supplied trap seal primer valve shall supply water to the trap. Water supplied trap seal primer valves shall conform to ASSE 1018. The quality of reclaimed or gray water supplied to trap seal primer valves shall be in accordance with the requirements of the manufacturer of the trap seal primer valve. The discharge pipe from the trap seal primer valve shall connect to the trap above the trap seal on the inlet side of the trap.
    1002.4.1.3 Waste Water Supplied Trap Primer Device. A waste water supplied trap primer device shall supply water to the trap. Waste water supplied trap primer devices shall conform to ASSE 1044. The discharge pipe from the trap seal primer device shall connect to the trap above the trap seal on the inlet side of the trap.
    1002.4.1.4 Barrier Type Trap Seal Protection Device. A barrier type trap seal protection device shall protect the floor drain trap seal from evaporation. Barrier type floor drain trap seal protection devices shall conform to ASSE 1072. The devices shall be installed in accordance with the manufacturer’s instructions.
    Same here in all cases where they have maintenance personnel.
    #9 Francis Vineyard, Mar 22, 2018
    JBI likes this.
Share This Page
