    Dismiss Notice
    Dismiss Notice
Have I reached the exit yet?
Discussion in 'Commercial Building Codes' started by JPohling, Apr 11, 2018.
  1. cda
    cda Sawhorse
    Oct 19, 2009
    14,654
    836
    Not sure agree
    Say you have a restaurant with a patio.
    Part of the exiting is through the patio
    I do not think you add the restaurant ol to the patio ol??
    Assumed patio people are gone or going when the restaurant people start leaving
  2. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,399
    202
    With a restaurant you "never" assume anything. The volume can alter from minute to minute.
    FD looks at worse condition not owners optimum. Consider holiday and sporting event crowds.
  3. cda
    cda Sawhorse
    Oct 19, 2009
    14,654
    836
    Yes but there is a design ol and exiting
    Can not control overcrowding, except to empty the place
    Set there and watch the pre paid fight till it is over.
  4. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,739
    539
    If the door leading to the patio dining area is signed as an exit and is a raised area or enclosed with a fence or guard as required here when serving alcohol outdoors then we use the cumulative load requirements and would require two exits off the patio dining area.
  5. cda
    cda Sawhorse
    Oct 19, 2009
    14,654
    836
    I am waiting for an exit plan for this thread
  6. JPohling
    JPohling Sawhorse
    Aug 16, 2011
    798
    48
    It is attached to my initial post???
    my250r11 likes this.
  7. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,399
    202
    Word pictures often miss the point, your plan says it all.
    That courtyard is a real gore (collection) point.
    Wish I had opened it earlier.
    If each room were to evacuate at the same time in a panic, ouch!
  8. JPohling
    JPohling Sawhorse
    Aug 16, 2011
    798
    48
    Fire Marshall has agreed that this plan is acceptable. Re name the area above the stair to Egress Court (no occupancy) and we are good.
    This is an area that is say 30'x30' that is immediately adjacent to a 10'-0" wide stair. Even if the total occupant load of the building were to exit at once to this spot they would all be able to make their way to grade within a minute.
  9. cda
    cda Sawhorse
    Oct 19, 2009
    14,654
    836
    Exit plan as will this thread ever end
  10. cda
    cda Sawhorse
    Oct 19, 2009
    14,654
    836
    Yea
    I do not have to use my parachute
  11. north star
    north star Sawhorse
    Oct 19, 2009
    3,539
    200
    Thanks for the update **JPohling** !.......In an effort to
    promote this Forum, would the Fire Marshall in your
    topic be interested in visiting here, ...possibly becoming
    a Sawhorse ?
    I'm trying to promote this MUCH VALUED resource. :D
  12. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,414
    98
    This is a problem because the court is 30' wide than the stairway is only 10' wide. Doors have an exception but stairways don't:
    The 2nd paragraph of 2009 IBC 1027.5.1 Where an egress court exceeds the minimum required width and the width of such egress court is then reduced along the path of travel, the reduction in width shall be gradual.
  13. sergoodo
    sergoodo Sawhorse
    Oct 27, 2009
    161
    6
    6 exists to the exterior of the building 2 maybe 3 required due to occupancy load. Should be able to show the building complies using the 3 S & E exits only, negating the exit access/egress court interpretation. The court will be used as an 2nd exit required for the patio occupants safety which is not required for the building occupant safety.
    In other words, flip the doors from the patio and add 1/2 the patio occupants to the Building S/E egress access.
    Building required exits (2-3): S& E
    Patio required exits(2) Building S/E & exit court
    The Fire Marshall should agree the patio now has 2 exits
    #33 sergoodo, May 5, 2018
Share This Page
