    Dismiss Notice
    Dismiss Notice
Height of fire alarm
Discussion in 'Commercial Fire Codes' started by Rick18071, Aug 29, 2017.
  1. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,414
    98
    Plans where reviewed and passed a couple of years ago. The plans of the building do not show the conveyors which are on a different permit and set of plans. The building is 90% finished and the conveyors are 50% finished. As the conveyors are being built they block the strobes and so the strobes would have to be moved above and below the required height by the NFPA.
    Just want to know how to proceed on inspecting the fire alarms if they can't be where the code requires them.
  2. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,414
    98
    So they need to go to the appeal board to move the strobes higher and lower than the maximum and minimum required by the NFPA that is in current use in PA?
  3. cda
    cda Sawhorse
    Oct 19, 2009
    14,654
    836
    Require the fire alarm company to either install per NFPA 72
    Or if you want plans, have the fire alarm company redraw and submit for review.
    The convyer problem is an easy fix
  4. jpsconsultingengineers
    jpsconsultingengineers Registered User
    Apr 23, 2018
    8
    0
    Just try to check the plan.
  5. cda
    cda Sawhorse
    Oct 19, 2009
    14,654
    836
    Welcome
    We always need structure!!!
  6. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,399
    202
    AHJ can accept alternate methods and means with justification, justification: later NFPA.
Share This Page
