    Dismiss Notice
    Dismiss Notice
How to determine Design Load bearing, wind, and seismic
Discussion in 'Architects & Engineers' started by Zarathustra, Jul 31, 2017.
  1. Zarathustra
    Zarathustra New Member
    Jul 31, 2017
    1
    0
    Greetings! My gf and I bought land in Hand we are allowed to draw up our own plans without an architects approval given the size of the building. I am using plans I found online with slight modifications but don't know how to determine these criteria they ask for:
    Live flood load
    Live Roof load
    Basic Wind speed
    Effective wind speed
    Wind exposure category
    Seismic design category
    [​IMG]
  2. cda
    cda Sawhorse
    Oct 19, 2009
    13,355
    659
    Seek professional help, if you want your house to last.
    You will actually save money, by spending it in the right places
    You cannot post pictures until you are a paid forum supporter
    You can post a link
  3. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,424
    546
    If I see it correctly, you would be looking for the Virginia Building Code and I do believe it is readily available online. One of our Va folks may chime in with a link, but as CDA says, a good designer may be able to save you some money and/or headache.
  4. MtnArch
    MtnArch Sawhorse
    Dec 25, 2009
    265
    24
    Looking at the linked image it says it's from the County of Hawai'i which I'm assuming is on one of the Hawaiian islands. It really would be best to contact a design professional from where you are looking to build to help you out. I think you'll find most of the plans you find online will only provide partial plans at best, and most need to be heavily modified to fit the locale that you'll be in. Most folks I've heard of that tried submitting what they bought online were politely turned away at the building department counter with a suggestion to contact someone local to provide the missing information.
  5. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    9,189
    388
    Contact the Local Building Department for the following: (It varies)
    Basic Wind speed
    Live floor loads and Live Roof loads are found in the code books
    If you do not Know these things, contact a design professional
  6. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,215
    234
    The online plans I receive generally are not acceptable as construction drawings. Particularly when I receive plans drawn using the IRC. Usually takes about 2 hours to do a residential review...Online plans can take two days to a week to review. You probably won't pay much more to have someone re-draw the online plans you've found and they can make little changes for you to make the house yours.
  7. mark handler
    Oct 25, 2009
    9,189
    388
    For a roof typical Live Load = 20 psf; may be different depending on roof slope. plus snow and dead loads when applicable
    For a floor a typical Live Load = 40 psf for residential occupancies. plus dead and concentrated loads when applicable
Share This Page
