    Dismiss Notice
    Dismiss Notice
IEB Code Question of the Day 2 Aug 2018
Discussion in 'Existing Buildings Codes' started by north star, Aug 2, 2018.
  1. north star
    north star Sawhorse
    Oct 19, 2009
    3,504
    186
    ...continuing with this topic, I have a detour here.
    I am reviewing plans for a facility, and they plan to replace
    approx. 20 rooftop units......Presently there are no GFCI
    rated receptacles installed anywhere on the roofs.
    This project also proposes to pressure wash & paint the
    exterior walls, ...construct 5 new steel structures without
    any walls, to house mobile Generators, and to replace an
    existing elevator inside one of the main bldgs.......These
    new steel structures are designed to meet the wind & structural
    loads of the region and to provide the necessary electrical
    components to be able to quickly connect the Generators
    to the adjacent bldgs.......The approx. price tag on this
    project is $1.7 mil.
    QUESTION # 1: The RDP has listed the ICC\ANSI A117.1
    & the ADAAG as two of the Standards for compliance on
    this elevator.........Because of the listing of the Accessibility
    Standards, am I to assume that the rest of the facility "should
    be" accessibility compliant ?........There is no mention of, or
    listing of any other Accessibility Standards on this project.
    I perceive that the RDP is not being fully forthright on the
    Scope of what is required.........My dilemma is this, is there a
    "requirement" to have this project spend up to 20% for
    Accessibility compliance ?..........NOTE: In the past, some
    RDP's have stated that compliance [ and budget ] was \ is not
    part of their contract.
    I am seeking Code & Standards sections that will assist me
    in determining when should the "up to 20%" is required to be
    spent.......In this case, the applicable Codes are the `15 I-Codes,
    including the IEBC, and the `09 A117.1.
    Thanks for any input !
  2. Builder Bob
    Builder Bob Sawhorse
    Oct 17, 2009
    1,821
    207
    existing building 20% accessibility improvement - it sound like they may have hit close to this price tag with an ada compliant retrofit elevator
    Accessibility requirements would be under alterations or repairs in the IBC or IEBC. Unfortunately, it will be the designer's responsibility to ensure that the scope of the project is reflected in the construction documents to include - method of compliance with IEBC - prescriptive, work area, or performance. only then will you truly know if the 20% rule is applicable.
  3. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,705
    519
    From what you describe the 20% does not apply to this project
    3411.7 Alterations affecting an area containing a primary function.
    Where an alteration affects the accessibility to, or contains an area of primary function , the route to the primary function area shall be accessible . The accessible route to the primary function area shall include toilet facilities or drinking fountains serving the area of primary function .
    1. The costs of providing the accessible route are not required to exceed 20 percent of the costs of the alterations affecting the area of primary function .
    2. This provision does not apply to alterations limited solely to windows, hardware, operating controls, electrical outlets and signs.
    3. This provision does not apply to alterations limited solely to mechanical systems, electrical systems, installation or alteration of fire protection systems and abatement of hazardous materials.
    4. This provision does not apply to alterations undertaken for the primary purpose of increasing the accessibility of an existing building, facility or element.
  4. north star
    north star Sawhorse
    Oct 19, 2009
    3,504
    186
    Much Thanks to you **Builder Bob** & **mtlogcabin** !
    BB, ...I am trying to obtain info from the RDP on a number of aspects
    of the plans submitted.
    mtlogcabin, ...there is no Ch. 34 in the `15 IBC any longer......It
    was removed........Now, everything comes out of the IEBC or the
    Property Maintenance Code ( IPMC ), but "Thank You" anyway for
    the reference.......That is still some good reading and information,
    as part of my due diligence.
  5. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,705
    519
    Everything that was in Chapter 34 is included in the IEBC. So the language is there in the prescriptive (IBC Chapter 34) and level 1 alterations compliance methods
  6. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,367
    83
    You did't say if the building has an accessible route to the area containing a primary function including toilet rooms and drinking fountain. If it does your done.
  7. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,705
    519
    From reading the OP non of the work being done is in a primary function area except the elevator replacement which will have to meet today's accessibility requirements. See exception 4 above.
    Additional funds can not be required to be spent on accessibility if the work being done is to improve accessibility which the replacement of the elevator should do (unless it is a freight elevator car).
    Pcinspector1 likes this.
Share This Page
