    Dismiss Notice
    Dismiss Notice
Insulation in a hollow steel structural tube
Discussion in 'Commercial Energy Codes' started by Simonsays, Aug 4, 2017.
  1. Simonsays
    Simonsays Bronze Member
    Mar 2, 2010
    47
    0
    Is there code language requiring placing insulation in a hollow steel structural tube in an exterior wall? (There will be no reduction in thermal transfer as the heat will flow around the metal shell.)
  2. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,740
    653
    There is a requirement to have an envelope that meets code...I can't imagine that a hollow tube exposed on both sides would, but who knows...Prove it!
  3. conarb
    conarb Sawhorse
    Oct 22, 2009
    3,251
    231
    As a builder who has built several homes with red iron frames I can tell you that I want my steel to be heated by the heat in the house, otherwise condensation can develop on the steel creating damage to the sheetrock/plaster. I had one inspector tell me that he had two homes in his jurisdiction that were "raining" inside from the condensation on the steel in the roof structure.
  4. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,740
    653
    Sounds intelligent to put the insul on the outside...
  5. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,394
    225
    Not exactly sure if I understand your design but I would think that the steel tube would be cold in winter and hot in summer if not properly isolated. Vermiculite poured in the hollow steel tube comes to mine but it may have asbestos issues. Maybe another pour-able insulator could be used. I still believe your required to meet the building wall insulation requirement for your zone.
    Can the the steel be wrapped with insulation or is that already being proposed? Spray foam?
  6. conarb
    conarb Sawhorse
    Oct 22, 2009
    3,251
    231
    It would take a massive change on the way steel structures are designed and fabricated, most columns are tubular and most beams are WF, the most targeted areas are the column to beam connections so there is no way to open them up to pour insulation into them. The only way I can see to accomplish it would be to have the insulation installed in the fabrication shop after the steel is cut and before the plates are welded in place, engineers require as much welding as possible to be done in the shop and not on site.
    Smaller insulators don't want to touch jobs with steel, those who want to try to blow foam in cavities around the steel, on the other hand most failures occur in spray foam buildings, so it's touchy. On one house I had the inspector at frame inspection ask: "You aren't going to be using spray foam here are you?' When I said no he just said good. Later I had a plasterer bidding the stucco and he saw steel in an overhang, he asked if there was spray foam in the house and when I said no he said: "Good, we have been named in two lawsuits on spray foam houses and our stucco had nothing to do with it."
    Pcinspector1 likes this.
  7. Francis Vineyard
    Francis Vineyard Sawhorse
    Jan 1, 2010
    3,061
    406
  8. conarb
    conarb Sawhorse
    Oct 22, 2009
    3,251
    231
    As a practical matter I remove the insulation on the inside of steel columns after insulation inspection and before sheetrock, even with inspectors I know who allow me to leave it out the damn insulators insist on putting it in saying it violates Title 24 to leave it out.
  9. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,371
    314
    It is waste of both time and money to insulate inside a hollow steel tube. The conductivity of the steel will cause the heat flow to be around the outside. Without doing any calculations, I would guess that the payback period on the insulation would be longer than the anticipated lifespan of the building by a respectable margin. As others have stated, insulate on the outside.
  10. north star
    north star Sawhorse
    Oct 19, 2009
    3,542
    201
    Can anyone cite Code Sections to support their positions,
    ...one way or the other [ i.e. - is there specific code language
    that requires hollow steel tubing to be thermally insulated,
    either internally or externally ? ]
    Thanks !
  11. Hamzah_12
    Hamzah_12 Registered User
    Jul 27, 2017
    1
    0
    I'm planning to increase the RValue in my exterior wall by filling the HSS with Spray foam insulation. There is already insulation in this cavity. 1.5" to the HSS from the outside aluminum skin.
  12. cda
    cda Sawhorse
    Oct 19, 2009
    14,657
    836
    Welcome Hamzah !
  13. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,371
    314
    You will likely not see any increase of Rvalue due to the high conductivity of the steel. If you want to increase the Rvalue in this are, you need to wrap the HSS.
    jeffc and JBI like this.
  14. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,732
    262
    Agree with others, a waste of perfectly good insulation and money with no appreciable benefit. Continuous exterior insulation will provide the increased energy efficiency you are looking for without necessarily causing long term harm.
  15. Robert
    Robert Sawhorse
    Jan 29, 2016
    147
    15
    I believe there is a requirement in the energy code (CA) for continuous exterior insulation for steel framed and studded buildings. We also needed it in addition to batt insulation in the stud bays to meet T24. Something tells me with the increasing energy requirements in CA, continuous exterior insulation will be required in wood framed buildings too...just a matter of time and what climate zone you are in.
Share This Page
