    Dismiss Notice
    Dismiss Notice
Is there an Electrical building Code for running an Extension cord?
Discussion in 'Commercial Electrical Codes' started by watai0102, Jul 6, 2017.
  1. watai0102
    watai0102 Member
    Jul 4, 2017
    13
    0
    Hi,
    In regards to NFPA and/or Building code, primarily for the state connecticut. Is there a violation with the following:
    220Vac
    Connect a junction box to the back of my stove and tap off the 220Vac or plug spllitter and run a extension cord from inside to outside (about 50ft) then back inside to the basement.
    120Vac
    Run an extension cord in the same manner as stated above.
  2. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,375
    534
    Are you talking short term or emergency? Long term, cords are not allowed to serve as a substitute for permanent,premises wiring (with a few exceptions) per the NEC and someone might give you that code section.
  3. FLSTF01
    FLSTF01 Sawhorse
    Jan 15, 2015
    92
    31
    2014 NEC Article 400.8 The answer is no, you may not use as a substitute for permanent wiring or run cord through walls or floors.
    Gregg Harris and steveray like this.
  4. Gregg Harris
    Gregg Harris Gold Member
    Jan 17, 2012
    882
    6
    The equipment is not UL listed for cord and plug usage along with other stated reasons
  5. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    870
    91
    One of the reasons for an electrical code is fires caused by overuse and improper use of extension cords.
Share This Page
