    Dismiss Notice
    Dismiss Notice
Level 1 Alteration - Toilet Room Accessibility?
Discussion in 'Existing Buildings Codes' started by Mech, Nov 1, 2018.
  1. Mech
    Mech Sawhorse
    Oct 30, 2009
    730
    11
    2009 IEBC
    Work is limited to two public use toilet rooms - changing floor and wall tile, changing plaster ceiling to gyp board, replacing toilet partitions and plumbing fixtures, changing light fixtures, changing HVAC grilles, and adjusting electrical switch height. There is no floor space reconfiguration except the possibility of shifting plumbing fixtures and partitions to meet IPC requirements.
    Must ICC A117.1-2009 be followed in its entirety if not providing an accessible family or assisted-use toilet room (605.1.10)? The water closet compartments do not have the required floor spaces and without tearing down walls, they cannot be made compliant; also, compartment doors swing into the insufficient toilet clear floor spaces. If the door swing is reversed, then there will not be 18" clearance on the latch side of the door to pull it open.
    Thanks,
  2. jpranch
    jpranch Platinum Member
    Oct 17, 2009
    1,881
    68
    Just went through this a few weeks ago with a very large assembly facility. Pretty much the same as your description and did it as a Level-1 using the IEBC. I did not make them do anything with accessibility. I'm sure I got it right but if I got it wrong someone please show me the error of my ways.
  3. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,811
    569
    How many water closet/urinals in each toilet room?
  4. Mech
    Mech Sawhorse
    Oct 30, 2009
    730
    11
    Men's room - 1 WC, 2 Urinals, 2 Lavs
    Women's room - 2 WC, 2 Lavs
  5. jpranch
    Oct 17, 2009
    1,881
    68
    Rut-Row! 2018 IEBC Section 305.6 and Section 305.8.10? I received a lesson from one of the top ICC instructors just yesterday and it is now my understanding that Chapter-3 applies to all methods. Btw, a lot of sections have been moved from the 2015 edition to Chapter-3 in the 2018 edition.
    JBI likes this.
  6. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,811
    569
    I would look at dropping a lav or urinal from the total fixture count and see if it will work before I do nothing
    JBI likes this.
  7. north star
    north star Sawhorse
    Oct 19, 2009
    3,572
    206
    Mech,
    FWIW, ...I agree with **mtlogcabin** !......IMO,
    it [ might ] go better to the owner "IF" the DOJ
    ever did any type of Accessibility compliance
    inspection, and found at least One compliant
    RR, for each gender, rather than "just barely"
    out of compliance.
    At least the owner will have tried to comply
    with the applicable Accessibility standards,
    albeit with less plbg. fixtures.
  8. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,808
    668
    Who has the decision of technical infeasibility in your jurisdiction? Typically you have to spend the 20% no matter what, unless it is technically infeasible. Or you could possibly say that the purpose of the remodel is to increase accessibility and wiggle out that way...
    705.1 General. A facility that is altered shall comply with the
    applicable provisions in Sections 705.1.1 through 705.1.14,
    and Chapter 11 of the International Building Code unless it is
    Where compliance with this section is
    technically infeasible, the alteration shall provide access to
    the maximum extent that is technically feasible.
    A facility that is constructed or altered to be accessible
    shall be maintained accessible during occupancy.
    705.1.10 Toilet rooms. Where it is technically infeasible to
    alter existing toilet and bathing rooms to be accessible, an
    accessible family or assisted-use toilet or bathing room constructed
    in accordance with Section 1109.2.1 of the International
    Building Code is permitted. The family or assisted-use
    toilet or bathing room shall be located on the same floor and
    in the same area as the existing toilet or bathing rooms.
    705.2 Alterations affecting an area containing a primary
    function. Where an alteration affects the accessibility to a, or
    contains an area of, primary function, the route to the primary
    function area shall be accessible. The accessible route to the
    primary function area shall include toilet facilities or drinking
    fountains serving the area of primary function.
    1. The costs of providing the accessible route are not
    required to exceed 20 percent of the costs of the
    alterations affecting the area of primary function.
    2. This provision does not apply to alterations limited
    solely to windows, hardware, operating controls,
    electrical outlets and signs.
    3. This provision does not apply to alterations limited
    solely to mechanical systems, electrical systems,
    installation or alteration of fire protection systems
    and abatement of hazardous materials.
    4. This provision does not apply to alterations undertaken
    for the primary purpose of increasing the
    accessibility of a facility.
  9. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,486
    117
    Forget about 705.2. A toilet room is not a primary function.
    PRIMARY FUNCTION. A primary function is a major
    activity for which the facility is intended. Areas that contain a
    primary function include, but are not limited to, the customer
    services lobby of a bank, the dining area of a cafeteria, the
    meeting rooms in a conference center, as well as offices and
    other work areas in which the activities of the public accommodation
    or other private entity using the facility are carried
    out. Mechanical rooms, boiler rooms, supply storage rooms,
    employee lounges or locker rooms, janitorial closets,
    entrances, corridors and restrooms are not areas containing a
    primary function.
    In PA an inspector is not allowed to decide if something is technically infeasible. It must be decided by a state board.
  10. Mech
    Mech Sawhorse
    Oct 30, 2009
    730
    11
    Thanks for the responses so far.
    I was able to reconfigure the two restrooms to make them comply with A117.1, except for the doors into the toilet rooms. If they want accessible doors, they need to frame out some new ugly walls and project them into the hallway to make the doors work. There is a structural column on one side of each toilet room door and what appears to be a plumbing / HVAC chase on the other side of each door.
    605.2 Alterations affecting an area containing a primary function. Where an alteration affects the accessibility to a, or contains an area of, primary function, the route to the primary function area shall be accessible. The accessible route to the primary function area shall include toilet facilities or drinking fountains serving the area of primary function.
    1. The costs of providing the accessible route are not required to exceed 20 percent of the costs of the alterations affecting the area of primary function.
    2.
    3.
    4.
    Is this saying that the accessible route includes the route to the toilet facilities and drinking fountains?
    Is it saying that restrooms and drinking fountains are included in the definition of accessible route, which means 20% of the alteration cost can be spent bringing toilet rooms and drinking fountains into compliance?
  11. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,808
    668
    Yep....Like Rick said, not primary function, but part of the accessible route for the primary function....Makes perfect sense...Right?
  12. Mech
    Mech Sawhorse
    Oct 30, 2009
    730
    11
    Clear as mud.
  13. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,577
    218
    Just do it! Stop looking for "outs". Its Federal law for the building owner/tenant.
  14. Tim Mailloux
    Tim Mailloux Registered User
    Feb 12, 2018
    73
    2
    I recall that A117.1 or the IBC allows automatic door operators in leu of providing the required 18" pull side latch clearance, if that helps.
  15. mp25
    mp25 Registered User
    Jun 2, 2016
    68
    13
    ...with standby power so people can get out in case of an emergency - if manual clearances are not available from the egress side
Share This Page
