    Dismiss Notice
    Dismiss Notice
Los Angeles CA - Single Family Curved Residential Stairs
Discussion in 'Residential Building Codes' started by Remington, Jun 13, 2018.
  1. Remington
    Remington Registered User
    Apr 16, 2018
    15
    0
    I am designing a curved staircase with a thread depth of 6" at it's smallest point and 11" , 12 inches away from the edge of the 6" edge.
    For Group R-1 occupancy, a Single Family home, do the curved stairs have to meet the curved stairs code requirement as specified below? It seems ridiculously difficult to comply in a small entry space.
    Curved stairways with winder treads must meet the minimum and maximum tread and riser requirements per Section 1009.4. Specifically, a minimum 11 inch tread depth, measured at a right angle to the tread's leading edge at a point 12 inches in from the side where the treads are narrower, is required; a minimum tread depth of 10 inches is required; and riser heights shall be 4 inches minimum and 7 inches maximum. Also, the smallest radius of the stair shall not be less than twice the required width of the stairway (radius requirements need not be met within Group R-3 occupancy or an individual dwelling unit within Group R-2 occupancy).
  2. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    9,745
    574
    Group R-1 occupancy, a Single Family home?
    Is it a R-1 zoning designation? Or A R-1 Group per the Building code?
    Single Family home per the State code is an R-3 and under the Residential code not the building code.
    my250r11 likes this.
  3. Remington
    Apr 16, 2018
    15
    0
    This is an R-1 zoning designation.
  4. Remington
    Apr 16, 2018
    15
    0
    The single family home is in R1 zoning
  5. mark handler
    Oct 25, 2009
    9,745
    574
    Zoning has nothing to do with the building codes
    In CA you are under the Residential Building Codes
  6. Remington
    Apr 16, 2018
    15
    0
    yes. I know. But can a curved stair with 6" min be allowed in a single family home?
  7. mark handler
    Oct 25, 2009
    9,745
    574
  8. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,479
    235
    Not on CA code but:
    2012 IBC 1009.12 Spiral stairways- shall have a 7.5-inches minimum clear tread depth at a point 12-inches from the narrow edge. Riser height shall not be more than 9.5-inches.
    RESIDENTIAL, 2012 IRC R311.7.10.1 Spiral stairways- 7.5-inch minimum tread depth @ 12-inches from the narrower edge. All treads to be identical and rise to be no higher than 9.5-inches.
    Both require a minimum of 26-inches clear width above and below the handrail. Head room can be 78-inches.
    Sooo... at the narrow end, 6-inches is too small
    That's what she said!
  9. Pcinspector1
    Oct 28, 2009
    2,479
    235
    I did't know this was referencing winder treads, R311.7.5.2.1, 6-inches is allowed at any point within the clear width of the stairs. Poster said curved stair, my mistake.
    Nice reference, MH
Share This Page
