    Dismiss Notice
    Dismiss Notice
Michigan Residential Electrical Code?
Discussion in 'Residential Electrical Codes' started by watai0102, Jul 6, 2017.
  1. watai0102
    watai0102 Member
    Jul 4, 2017
    13
    0
    我正在完成我的地下室。我只是想知道有没有人可以给我一些关于密歇根州住宅电气代码的提示(每个电路的插座数量,地下室的所有插座都需要是GFI,电线尺寸等)我计划运行(2)15安培电路。过去我已经做了一些小的电气应用,所以我并不是完全无知的。我只是想确保,如果我以后卖这个房子,一切都将符合密歇根州的代码。提前致谢!!
  2. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,184
    227
    Courtesy Google Translate...
  3. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,375
    534
    Get a permit, and get it inspected, and then it will comply.....
  4. north star
    north star Sawhorse
    Oct 19, 2009
    3,340
    158
    CAUTION: Please post all topics in English on this Forum,
    otherwise you [ may ] be considered to be a Spammer,
    a robot or something else undesirable to this community,
    and thus, ...your response will be removed !
  5. rogerpa
    rogerpa Silver Member
    Nov 5, 2009
    202
    29
    Michigan currently uses an amended version of the 2015 IRC (https://codes.iccsafe.org/public/document/toc/553/) for all one and two family residential dwellings (which includes electrical requirements). The amendments are contained in Part 5 of the Administrative Rules.
    http://w3.lara.state.mi.us/orr/Files/AdminCode/1182_2013-022LR_AdminCode.pdf.
    Also see http://www.michigan.gov/documents/lara/2015_Michigan_Residential_Code_Errors_and_Conflicts_v2_549200_7.pdf.
    All requirements for AFCI's (E3902.15,16, and 17) have been deleted.
  6. rogerpa
    Nov 5, 2009
    202
    29
    Should have also said, electrical requirements are in Chapters 34-39.
  7. cda
    cda Sawhorse
    Oct 19, 2009
    13,185
    626
    Non of that non English code talk
  8. sspan
    sspan Sawhorse
    Jul 12, 2016
    3
    0
    NEC 可以使用15安培綫跑燈或插座,建議插座用12號綫不要用14號,可以減少損耗。
    商業一個雙插座算180瓦,住宅沒有硬性規定,一般是14號线最多10個插座,建議最多7個,12號線最多13個建議最多8個。
    地下室全部gfci。
  9. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,184
    227
    Again, thanks Google Translate... Seems to do a great job.
    NEC can use 15 amps running lights or sockets, it is recommended that the socket line 12 do not use No. 14, can reduce the loss.
    Commercial a double socket count 180 watts, residential no hard rules, generally 14 lines up to 10 sockets, the proposed maximum of 7, 12 lines up to 13 recommendations up to 8.
    Basement all gfci.
  10. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,095
    130
    [QUOTE全[/QUOTE]
  11. Pcinspector1
    Oct 28, 2009
    2,095
    130
    I think this means house
  12. cda
    cda Sawhorse
    Oct 19, 2009
    13,185
    626
    I am glad we reach all ends of the world!!!
    Maybe I can get
    Bitte ein bit??
    #12 cda, Jul 21, 2017
Share This Page
