    Dismiss Notice
    Dismiss Notice
New build: stub out closet for future bathroom
Discussion in 'Residential Plumbing Codes' started by tnerb11, Jan 8, 2018.
  1. tnerb11
    tnerb11 Member
    Jan 8, 2018
    5
    2
    Hello,
    I am in the process of a new build and have asked my developer for a quote to have plumbing stubbed out in an upstairs closet so I can convert this to a bathroom in the future. When asking for a quote, the builder mentioned that this is probably not possible due to building codes (Bend, OR in Deschutes County). I wanted to see if this community may have run across this before so I can better understand what the concern is here. I've read through the local code here and cannot find any details for this.
    Any help would be appreciated.
    Thanks!
  2. fatboy
    fatboy Administrator
    Oct 17, 2009
    5,239
    275
    Welcome!
    No idea why the closet could not be properly roughed in for future use, no different than a basement. I suppose it could be a local thing.
  3. cda
    cda Sawhorse
    Oct 19, 2009
    13,185
    626
    Welcome
    Not a plumber, but same conclusion
    The ahj may want a few more bathroom things, maybe exhaust, glif
    As always be like rocket man, launch it see if it flys with the ahj.
    Maybe mark the room for future use or similar, so the ahj at least knows what you are trying to do.
    Should be silimlar to unfinished basement
  4. Inspector Gift
    Inspector Gift Sawhorse
    Oct 17, 2009
    203
    16
    Best to ask the jurisdiction directly. Many parts of Oregon have strict requirements governing water supply and septic systems.
    #4 Inspector Gift, Jan 8, 2018
    ICE likes this.
  5. tnerb11
    tnerb11 Member
    Jan 8, 2018
    5
    2
    Very helpful guys, thank you
  6. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,133
    45
    While your at it ask for a 20 amp wire to be installed. You need a 20 amp outlet in bathrooms.
  7. ICE
    ICE Sawhorse
    7,075
    451
    AFCI of course. And don’t forget an exhaust fan. A Solatube is a nice touch. Receptacles and lights can go in now. Same with a medicine cabinet. Do the whole thing in green board with backing where you'll need it. Get pictures so it will be easy to find the waste pipe for the toilet and tub/shower. If there's an exterior wall it will seem dumb without a window. Then insulate the interior walls to keep the noise down. And last but not least, I appreciate my laundry chute.
    About the only glitch here is the plans and permits. Get permits, or not, take your own crew in on a weekend and bang it out.
    #7 ICE, Jan 9, 2018
  8. Francis Vineyard
    Francis Vineyard Sawhorse
    Jan 1, 2010
    2,766
    268
    In reference to this thread New Build w/ Developer - Do I hire a home inspector I presumed you are working with a spec or track houses, not custom build. I would not be surprise if he is reluctant to accommodate designs not planned and may have not been accounted for under contract.
Share This Page
