    Dismiss Notice
    Dismiss Notice
No Longer an Exit
Discussion in 'Door & Hardware forum *Sponsored by Allegion' started by LGreene, Oct 23, 2018.
  1. LGreene
    LGreene Sawhorse
    Staff Member
    Oct 20, 2009
    1,090
    77
    I really need some help with this issue, so please weigh in. The building in question is being renovated, and the egress routes have changed. Some doors that were exits before, are no longer required as exits. The building owner wants to leave the existing doors and hardware, but permanently fix them in the closed position. They won't open any more, but they will still look just like the door openings that were previously used for egress.
    I know this should not be done - it's a hazard. But what do you point to in the codes to show that it is not allowed?
  2. Inspector Gift
    Inspector Gift Sawhorse
    Oct 17, 2009
    212
    23
    It is a fire/life/safety violation. We would not allow occupancy of the renovated buildings until the violations have been corrected. Either make the doors working exits, or remodel them so they do not appear as exits in any manner.
    jar546 and JBI like this.
  3. Sifu
    Sifu Gold Member
    Sep 3, 2011
    1,024
    68
    What makes the doors look like exits? If it is a sign or other markings, those must go. But if the concern is just a persons previous use and familiarity I am not so sure. After all, exit signs are for those that are not familiar with where the exits are. If a corridor has 10 office doors and 1 exit door could they not all look the same except for the exit sign and maybe the type of hardware? I acknowledge the requirement to not have an exit door disguised, but not sure I know of a code that would prohibit the condition you describe. Not in the fire code a lot so maybe there is something in there I am missing.
    Code requires that a door provided for egress purposes, whether required or not, must meet the code. But these are not doors that are being provided for egress purposes anymore.
    cda, JCraver and Rick18071 like this.
  4. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,486
    117
    What Sifu said
    JCraver likes this.
  5. JCraver
    JCraver Sawhorse
    Feb 20, 2014
    551
    190
    Take the exit signs off and it becomes just a door. It could go to the outside, it could go to an office, it could lead into another dimension. Doesn't matter, it's just a door. Lock it or fix it closed, redirect occupants to an approved, required exit, and no problems.
  6. cda
    cda Sawhorse
    Oct 19, 2009
    14,903
    869
    What others said
    If not used for a door for anything, I think minimum, remove any door hardware.
  7. Sifu
    Sifu Gold Member
    Sep 3, 2011
    1,024
    68
    That sounds like the door to my office.
    JCraver likes this.
  8. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    978
    123
    Panic bars should be removed because they imply an exit door. Regular locksets shouldn't confuse anyone.
  9. Builder Bob
    Builder Bob Sawhorse
    Oct 17, 2009
    1,920
    236
    Fire Code Issue ----
    Fire code states where a door is adjacent to or constructed similar to and can be confused, Approved signage that identifies room use or name shall be used to identify door.
    IFC1031.5 Non-exit identification.
  10. Sifu
    Sifu Gold Member
    Sep 3, 2011
    1,024
    68
    Fair enough, easy solution.
  11. cda
    cda Sawhorse
    Oct 19, 2009
    14,903
    869
    Wait a minute wait a minute
    Building under renovation
    Sounds like a building inspector issue
    Plus is the same language in IBC ??
  12. Builder Bob
    Oct 17, 2009
    1,920
    236
    Applicable section of the IBC which is not as clear as the intent of the section cited from the Fire Code.
    1010.1 Doors. Means of egress doors shall meet the requirements of this section. Blah Blah Blah..... .
    "Means of egress doors shall be readily distinguishable from the adjacent construction and finishes such that the doors are easily recognizable as doors." Blah, Blah, Blah...
  13. fatboy
    fatboy Administrator
    Oct 17, 2009
    5,471
    407
    The doors still look like doors, remove the signage.......go to go.
    It might take a while for someone familiar with it to get used to it, but a typical visitor looks for exit signage.
  14. Builder Bob
    Oct 17, 2009
    1,920
    236
    unfortunately, the signage provisions that are mandated in the IFC for non-exit identification requirement is not directly reflected into the building code requirements unless you adopt appendix E for signage. Thus it is a fire code issue.... the code wording in the IBC is weak, as any door can be recognized as a door.......Duh. It should have stated ... such that the doors are easily recognizable as EGRESS or EXIT Doors.
Share This Page
