    Dismiss Notice
    Dismiss Notice
Question About Corridor Doors NFPA 101 / 80
Discussion in 'Commercial Fire Codes' started by JItter77, Jan 11, 2018.
  1. JItter77
    JItter77 New Member
    Jan 11, 2018
    1
    0
    Hello,
    I work maintenance in a nursing home and have some questions regarding corridor doors. We are a single story facility with 4 wings. Each wing is basically its own smoke compartment with a 1 hour smoke wall and 1 hour rated doors / frames etc etc. Each wing consists of 15 resident rooms and some resident rooms have fire rated doors and others do not. According to NFPA 80 any door with a fire rated label must be inspected as such regardless of the surrounding walls and what not. In NFPA 101 version 2012 under corridor doors (19.3.6.3) section 19.3.6.3.3 says that "compliance with NFPA 80 is not required." How i interpret section 19.3.6.3 in general is that that corridor doors that are not part of a smokewall / firewall / hazardous rooms are only required to resist smoke and not follow the much stricter guidelines of NFPA 80 even if the door has a label. All rooms have a smoke detector and the hallway / rooms are fully on automatic sprkinlers.
    If anyone could clear this up it would be great.
    Thanks
  2. cda
    cda Sawhorse
    Oct 19, 2009
    13,185
    626
    Welcome
  3. cda
    cda Sawhorse
    Oct 19, 2009
    13,185
    626
Share This Page
