    Dismiss Notice
    Dismiss Notice
Question about outlet placement at a "counter" in a dining room
Discussion in 'Residential Electrical Codes' started by sand, Sep 22, 2018.
  1. north star
    north star Sawhorse
    Oct 19, 2009
    3,562
    203
    Is there a Gas Shut Off Valve located within 6 ft. of the
    unvented gas appliance ?.......Also, what is the material
    over the gas appliance made of ?.......Is it stone, or some
    type of combustible "faux looking stone" material [ i.e. -
    clearance to combustibles ].
    IMO, ...that area screams for receptacles, whether they
    are required or not......The owner will use it as a countertop
    and as a mantle ( t.v., ...lava lamps, ...stereo equipt.,
    ...crock-pots, etc. ).
    fatboy likes this.
  2. rgrace
    rgrace Sawhorse
    Feb 18, 2010
    142
    24
    I completely agree. That was poor planing on the electrical contractor. They should have insisted on some receptacle applications above that counter/work surface, using North Stars points as a means to convince the owner. Even an electronic picture frame that toggles through pictures requires power. If it were me ....... I'd be mounting a flat screen above that mantle and also place lamps on either side of it (the lighting in that room looks extremely weak) and include a couple of electronic picture frames.
    rogerpa likes this.
  3. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    9,706
    556
    Use Pop Up Outlets CEC Code 406.5(E) for Countertops, instead of wall outlets
    All the wiring in the "cabinet".
  4. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,483
    207
    "Nice", also great discussion about a topic that often comes up.
  5. north star
    north star Sawhorse
    Oct 19, 2009
    3,562
    203
    Technically, the area above the non-vented heating
    appliance is not a mantle, but rather cabinetry that
    will be used as a countertop........Mantles are above
    fireplaces !
Share This Page
