    Dismiss Notice
    Dismiss Notice
Question For Lori
Discussion in 'Door & Hardware forum *Sponsored by Allegion' started by Rider Rick, Mar 10, 2018.
  1. Rider Rick
    Rider Rick Silver Member
    Oct 19, 2009
    468
    0
    Rider Rick said:
    Here is my question stated in a different way....
    A quantity of 2 @ 90 minute fire doors prefit...meaning the machining will be done at the mfg.
    These will be double doors to be hung in the existing jamb. In my experience door always
    need to be fitted/planed to fit in the somewhat out of square jamb. By doing any fitting/planing ...
    ***(My question is)*** Does this void the fire certification/rating and therefore void the label of the fire door?
    Thank you!
  2. cda
    cda Sawhorse
    Oct 19, 2009
    14,453
    796
  3. LGreene
    LGreene Sawhorse
    Staff Member
    Oct 20, 2009
    1,074
    75
    Hi Rick -
    NFPA 80 addresses the allowable clearance which is measured after the door is installed in the frame, but doesn't specifically state whether it's ok to plane the door in the field. Undercutting the door is allowed by 80, but that's just at the bottom of the door. The question of whether it's ok to "adjust" the clearance at the top and sides would be up to the door manufacturer's listings. If you know the manufacturer you can call their tech support department to check. It's tricky because planing the door can affect the hardware preparations and the projection of the latch. You also need to avoid planing off the label!
    - Lori
    cda likes this.
Share This Page
