    Dismiss Notice
    Dismiss Notice
Self-Certification Program??
Discussion in 'Code Administration' started by Joker, Nov 14, 2017.
  1. Joker
    Joker Bronze Member
    Jun 26, 2014
    41
    1
    As I'm sure most of you are aware there are cities around the country (Chicago, New York, Phoenix, etc.) that are allowing Architects to go through training and then certify that their plans are code compliant. Have you been involved with a municipality that has an initiative like this? If so please advise how you were involved with that municipality, and share your experiences.
  2. cda
    cda Sawhorse
    Oct 19, 2009
    14,242
    781
    That is interesting
    Do they do the inspections also?
  3. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,701
    247
    Codes and code officials exist largely because design professionals (and contractors) did not necessarily do their jobs correctly.
    Letting the fox guard the hen house has never worked out very well...
    Ty J., Joker and fatboy like this.
  4. fatboy
    fatboy Administrator
    Oct 17, 2009
    5,366
    358
    Amen.... I'm with JBI.
    Joker and JBI like this.
  5. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    724
    65
    Pennsylvania had or (still has I think), an expedited plan review process, if a DP lists a disclaimer on the plans stating compliance with applicable codes the plan review time is reduced to 5 business days. When this was enacted we seen a rash of disclaimers and I can say a veryyyyy small majority made it through review the first go round or even the second. Further understand Pennsylvania does NOT have CEU requirements for Registered Architects.
    Joker or anyone who can answer, what is the reasoning behind the Design Professionals Self Certifying, delays, qualified plan reviewers????
    Joker likes this.
  6. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,701
    247
    Keystone, these are primarily large, active cities that are probably looking to either reduce or not increase their building departments as a cost control measure. NYC for example has a line outside the door before the start of almost every day. Expediters wait on line for hours at a time for 5 or 10 minutes with someone who can accept their submittals, or discuss applications.
  7. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,326
    287
    We had a similar proposal from our architects and engineer societies, that as they are registered professionals, they are intimately familiar with the codes and should not be under the same scrutiny, but they could not demonstrate that their members had the required knowledge based solely on their credentials.
    I would agree with JBI. We have had architects and engineers for much longer than building officials. There is a reason that society thought this was a necessary role.
  8. cda
    cda Sawhorse
    Oct 19, 2009
    14,242
    781
  9. Sifu
    Sifu Gold Member
    Sep 3, 2011
    947
    50
    I can think of a 1/2 dozen questions to ask right away that would disqualify most architects in my area. Most of our plans don't get off the code information page or life-safety analysis without comments. Is it because they don't know, too busy, too lazy, or just trying to please a client and get away with something? Take your pick, any way you slice it, JBI has it...... The fox in charge of the hen-house!
    Joker likes this.
  10. fatboy
    Oct 17, 2009
    5,366
    358
    Truth Sifu, code analysis alone typically triggers redline comments.
  11. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,666
    631
    I can barely get a plan that shows they are using the correct codes, nevermind analysis....
  12. Joker
    Joker Bronze Member
    Jun 26, 2014
    41
    1
    No
  13. Joker
    Joker Bronze Member
    Jun 26, 2014
    41
    1
    They're saying it reduces time drastically. This is merely speculation but maybe where it first started the city didn't have enough plan reviewers to handle the load at that time and the other cities fell in line because it sounded like a "Good Idea".
  14. Joker
    Joker Bronze Member
    Jun 26, 2014
    41
    1
    Everyone, Thanks for your replies. I'm also concerned about the Fox Factor. I've seen a boat load of bad plans and "creative" interpretations of the code by some of the so called best in our area. I'm glad that I have the support of my superiors so far. Cities like NY and Chicago doing it makes it very hard to push back when there's opposition from above.
  15. Mark K
    Mark K Platinum Member
    May 12, 2010
    1,297
    52
    Self certification kind of defeats the idea of having a building department.
    At one time NYC claimed that they had to go to certifications because of the size of the jurisdiction.
    this claim can be shown to be not real if you look at the Los Angeles building department. My sense is that they adopted self certification either because the managers of the department were not competent or because of politics.
    Any jurisdiction where expeditors are essentially required is likely to be prone to corruption.
    Before building departments get too self righteous it should be noted that engineers have stories about building plan checkers that do an inadequate job or are incompetent. Most engineers welcome a thorough plan check but have learned that they cannot count on the building department to find mistakes.
    JBI likes this.
  16. Builder Bob
    Builder Bob Sawhorse
    Oct 17, 2009
    1,794
    198
    Can I self certify that I haven't had to much to drink before I drive.....?? We know how well that works out every day.
    JBI likes this.
  17. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,214
    178
    Checks and balance are implemented just to prevent what you suggest "Bob".
    Are you trying to increase "Legal" business?
Share This Page
