    Dismiss Notice
    Dismiss Notice
So a HVAC contractor walks into a bar
Discussion in 'Mechanical Codes' started by cda, Nov 5, 2018.
  1. cda
    cda Sawhorse
    Oct 19, 2009
    14,903
    869
    Make that an office, and has a question
    What should they do if they find a house with a unit putting out
    1. Low levels of CO?
    2. Medium levels of CO?
    And the house owner does not want to fix it anytime soon??
    And winter is strarting/heater time.
    And a legitiment hvac company, not trying to make money, but maybe save lives and a day in court.
  2. ICE
    ICE Sawhorse
    7,552
    645
    Alert the gas company. Any time I have to alert the gas company they are there in minutes. Edison is nonchalant....the gas company is anal. Of course I get name, rank and serial number which I suppose scares some people. I like the gas company. My bill is $12 this month. I'll give'em a call if you want.
    #2 ICE, Nov 5, 2018
    mtlogcabin likes this.
  3. BLangley
    BLangley Registered User
    Sep 4, 2018
    3
    1
    Maryland recently had a case on similar facts:
    https://mdcourts.gov/data/opinions/cosa/2018/1719s16.pdf
    https://www.macdonaldlawgroup.com/blog/2018/08/maryland-court-of-special-appeals-expands-duty-of-service-contractors-to-inspect-and-to-warn-of-pote.shtml
    Sounds like they've warned and service was refused. Probably something they want to document explicitly with the owner's signatures. Also might be worth a call to their attorney to set a standard method. Certainly won't be the last owner to pick short-term wants and needs over their long-term health/life.
    JBI likes this.
  4. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    758
    78
    Great Post. Food for thought for all inspectors and contractors when encountering significant concerns.
    JBI likes this.
  5. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,808
    668
    Was it a bar or a water column?
    Mech likes this.
  6. linnrg
    linnrg Sawhorse
    Mar 17, 2015
    286
    65
    there have been contractors who write this up to gain extra work - I personally know one. I had called him to do a service and his report stated CO levels. I did not like his quote to do the repairs on an older boiler I had, so I called another contractor who came out and could not detect CO. I also had a CO Detector in that room that never went off (neither contractor knew this). Luckily for me I was able to get a energy grant and replaced that boiler with a high efficiency unit that no longer relies on natural draft.
  7. cda
    cda Sawhorse
    Oct 19, 2009
    14,903
    869
    I understand the vultures
    One debate is
    Where do you take the reading?
    Near the heat exchanger ?
    In the plenum?
    In a room down the way, where the co level may have disapted ??
Share This Page
