    Dismiss Notice
    Dismiss Notice
Under-slab dryer vent
Discussion in 'Residential Mechanical Codes' started by kyhowey, Jul 26, 2012.
  1. Rider Rick
    Rider Rick Silver Member
    Oct 19, 2009
    447
    0
    Well Thank You Greg,
    I had no idea that the dryer vent plastic/vinyl flex duct are not to code and were a fire danger.
  2. Francis Vineyard
    Francis Vineyard Sawhorse
    Jan 1, 2010
    2,766
    268
    #22 Francis Vineyard, Jul 26, 2012
  3. Francis Vineyard
    Jan 1, 2010
    2,766
    268
    RR I presume what you're seeing is the "flexible air connector" that is advertised as fire resistant UL 181 on the same shelf next to the dryer transition ducts. This is a common mistake made with air ducts and dryer ducts and I do wonder sometimes if it's done for the vender's convenience or a product marketing strategy to group the flexible ducts together in one place.
    Francis
  4. Rider Rick
    Oct 19, 2009
    447
    0
    Francis,
    I'm going to stop by Home Depot and take a better look but I didn't know there were two difference ones.
    I'm sure the air ducts are less money and I'll bet some people are hooking them to there dryers without knowing.
    Rick
  5. Gregg Harris
    Gregg Harris Gold Member
    Jan 17, 2012
    882
    6
    Thank you Francis
    I guess I was not the only one with the idea. Although I disagree with the action
    statements for denial Ad I will run tests on both gas and electric. There is always 2015
  6. Rider Rick
    Oct 19, 2009
    447
    0
    I went to Home Depot and you can't buy any plastic/vinyl flex ducting the dryer vent flex duct is rated at 450 degrees but the end of the line hood on the out side of the wall does have a screen.
  7. Francis Vineyard
    Jan 1, 2010
    2,766
    268
    How would you know the difference between flex dryer and air connector installed on the job?
    [​IMG]
    [​IMG]
    [​IMG]
    Francis
  8. Gregg Harris
    Jan 17, 2012
    882
    6
    Instead of having the UL 181 label it should have UL 2158 A label on the package. I am going to check a couple of suppliers in the next couple of days. The one I am using on my dryer does not have labeling on the ducting itself. I am trying to find someone with a gas dryer to run temperature tests on to compare them with my electric.
    Home Depot has on there web that the ones they supply are rated for electric but not gas. I am contacting MFG's to see if I can get more info.
  9. Doug Ables
    Doug Ables New Member
    Feb 22, 2017
    1
    4
    Codes state metal. As a dryer vent cleaner in the slab PVC vents are a terror to clean. The PVC creates static electricity as air moves over it, making lint stick to it more readily thereby creating a hazardous situation quickly. We rarely clean a slab vent that we do not get 5-10 gallons or more of lint out of it.
    Also the vents, due to their configuration create a trough for water to collect in. A normal load of clothes drying creates over a gallon of water in condensate. That water must be expelled from the vent. A slab vent will collect it until it has to be suctioned out. I have removed 17 gallons of water in one vent after a couple years use. The vents ruin the equipment that is made to clean dryer vents due to the 4-90 degree turns. Builders who install these useless vents should be made to clean them and see how much of a pain they are to us and the homeowner when we tell them they need to be rerouted. Also your comment about why are the plastic ducts sold at home depot if they are not meant to be used as a dryer vent. The answer is this....plastic vents are ok for air vents such as bathroom exhaust fans but not dryer vents. The only reason they are in the dryer vent area is the workers at HD and Lowes do not know any better. They are the same size and vents-so why not? When you add heat to plastic it becomes brittle and develops a hole. I have a picture of such an occurrence but don't know how to post it. But common sense tells me heat and thin plastic do not go together.
    fatboy, tmurray, ICE and 1 other person like this.
  10. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    870
    91
    Big boxes sell lots of stuff that doesn't meet code.
    tmurray likes this.
  11. Francis Vineyard
    Jan 1, 2010
    2,766
    268
    Mr. Doug Ables, welcome to the forum and thanks for the additional information and sharing your experience.
  12. north star
    north star Sawhorse
    Oct 19, 2009
    3,340
    158
    Doug Ables,
    Also, ...Welcome to The Building Codes Forum !
    To be able to post pictures \ images on to this Forum,
    one would need to become a Paid Subscription
    Sawhorse !........I am encouraging you and others
    to join and become Sawhorses.
    FWIW, ...the term Sawhorse was selected by the
    Forum owner and accepted by the membership.....It
    is a definition that; IMO, ...seems appropriate and fits
    very well. :D
  13. fatboy
    fatboy Administrator
    Oct 17, 2009
    5,239
    275
    Welcome to the forum, and way to come out swinging with a great post!
Share This Page
