    Dismiss Notice
    Dismiss Notice
Water heater install Q.
Discussion in 'Residential Plumbing Codes' started by Pcinspector1, Jul 13, 2017.
  1. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,095
    130
    Water heater in a residential garage listed with the FVIR (Flammable Vapor Ignition Resistant) not setting 18" above the floor. Would this be permitted or is it a violation?
  2. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    697
    55
    Not a violation.
    Pcinspector1 likes this.
  3. Pcinspector1
    Oct 28, 2009
    2,095
    130
    There should be a label stating it's a FVIR water heater, correct?
  4. fatboy
    fatboy Administrator
    Oct 17, 2009
    5,239
    275
    Is there testing/listings on this FVIR?
  5. north star
    north star Sawhorse
    Oct 19, 2009
    3,340
    158
    Yes, **Pcinspector1**, the FVIR listing is permitted to substitute
    the 18" min. height above the floor requirements [ RE: `12 IRC,
    Section P2801.6, the Exception. ].
    The water heater MUST have the original, approved listing affixed
    to it from the manufacturer.
    That said, I am VERY "old school".......I still prefer to have a storage
    type water heat to be elevated......IMO, it provides a safer & prudent
    install, regardless of the Exception.......Too much potential for other
    liquids to effect the bottom of the tank.
    But hey, what do I know ! o_O
    Joe Engel, Keystone and Pcinspector1 like this.
  6. Pcinspector1
    Oct 28, 2009
    2,095
    130
    First garage WH inspection here without a 18" high box.
    Gas company would not lite the WH and called asking if the code changed. Had to do some research, appreciate the info.
  7. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,485
    415
    If not then it is NOT an FVIR water heater. At bare minimum the ANSI/CSA Z21.10.0 should be on the unit
    How can I tell if my water heater is FVIR? Each manufacturer will have its own particular label for indicating if the model is FVIR. In general, water heaters manufactured to the American National Standard ANSI/CSA Z21.10.1 are required to be FVIR according to the following implementation schedule.
    steveray likes this.
  8. Pcinspector1
    Oct 28, 2009
    2,095
    130
    mtlogcabin,
    Couldn't find it anywhere on the WH or in the paper work, Bradford White 40 gal. This puts me in a pickle, the GasCo will not lite it if its sitting on the floor and the installer claims it's a FVIR. (after 2003 aren't they all suppose to be FVIR's). To complicate this, no permit was sought when it was installed. The good news is it's got an expansion tank.
  9. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,375
    534
    It doesn't put you in a pickle, it's the installer....
  10. cda
    cda Sawhorse
    Oct 19, 2009
    13,185
    626
    Ask for the installation instructions
    Or just take them off the top
  11. cda
    cda Sawhorse
    Oct 19, 2009
    13,185
    626
  12. Pcinspector1
    Oct 28, 2009
    2,095
    130
    Thanks cda, yes I do and I looked it up on BW's warranty search. Could not find any FVIR information on the tank but did see on the install instructions dated 2012 on the first page (Flammable Vapor Ignition Resistant), at first I was looking for the acronym FVIR when thumbing through the install instruction manual at the site. Still having issue with the Gasco, they will not lite the WH.
  13. cda
    cda Sawhorse
    Oct 19, 2009
    13,185
    626
    Does the house have gas service turned on??
    If so let the home owner lite it??
    Call a supervisor/ field person that has some common sense ??
  14. Pcinspector1
    Oct 28, 2009
    2,095
    130
    Gas off at the tank only, yes the installer or the home owner could turn the gas back on at the tank. The supervisor at the Gasco office is calling the shots.
  15. cda
    cda Sawhorse
    Oct 19, 2009
    13,185
    626
    Gasco need a class on fvir??
    Along with some type of agreement among all, how to get one approved and lit?
  16. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,485
    415
    If it has the ANSI/CSA Z21.10.0 then it is a FVIR if not he found an old unit the supply house is trying to dump out of their stock.
    Does the BW look like this
    http://www.bradfordwhite.com/defender-safety-system-%E2%80%93-fvir-technology
    [​IMG]
    How the Defender Safety System® Works
    The heart of Bradford White’s Defender Safety System® is the flame arrestor design of the patented ScreenLok® Technology. This precisely engineered and manufactured component is made 304L alloy stainless steel and contains up to eighteen thousand, geometrically oriented louvers. These micro dimensioned louvers increase the velocity of incoming air to the system. If flammable vapors enter this uniquely designed system and are ignited, a vector effect occurs inside of the combustion chamber. The combination of high velocity air entering the chamber and the vector effect caused by combustion will prevent any flames present in the chamber from traveling backwards through the flame arrestor plate and outside of the water heater.
    The Bradford White Defender Safety System® maintains outstanding efficiency, a long service life and very low NOx emissions. Best of all, it provides maintenance free operation while meeting the stringent ANSI standard for the affected gas water heaters.
    Advanced ScreenLok® Technology Flame Arrestor Design
    [​IMG]
    Included on all FVIR compliant models. ScreenLok® is constructed of 304L stainless steel, a non-rusting alloy, for outstanding impact, heat, crack, and corrosion resistance. The ScreenLok® Technology Flame Arrestor was tested in the harshest simulated environment and continued to operate properly over the normal life expectancy of the product.
  17. Pcinspector1
    Oct 28, 2009
    2,095
    130
    Yes the BW Defender WH has the ANSI Z21.10.1 and CSA 4.1 design, thanks for the information. This has been a real learning curve and there is not a problem IMO with an AHJ requiring the installation of one of these WH's above the floor at 18" in a garage.
    AHJ's should decide if they will allow the new water heaters to be set on the garage floor or to be raised 18" above the floor.
  18. ICE
    ICE Sawhorse
    7,075
    451
    The eighteen thousand, geometrically oriented, micro dimensioned, louvers tend to get clogged with dust. Then it doesn't work at all.
  19. my250r11
    my250r11 Sawhorse
    Feb 16, 2015
    239
    71
    Here any ignition source (WH, Dryer, ect.) needs to be elevated in a garage. Fumes can be ignited by any kind of flame or spark from within an appliance. We also use the UPC & UMC here.
  20. Joe Engel
    Joe Engel Member
    Jun 16, 2011
    29
    6
    Old School here, rather use the KISS (keep it simple stupid) method of reasoning. 18" platform not "required" given the manufactures manual and choice of unit but strongly recommended. Are there space issues? What if, sometime down the road the owner changes the unit out for a cheaper non-FVIR heater cause it wouldn't stay lit? Your gonna hear "but it met code before!"
Share This Page
