    Dismiss Notice
    Dismiss Notice
Why is water leaking from the furnace pipe in my attic?
Discussion in 'Residential Plumbing Codes' started by watai0102, Sep 29, 2017.
  1. watai0102
    watai0102 Member
    Jul 4, 2017
    11
    0
    I have a gas furnace that is approx 10 years old. There is a 5 inch galvanized furnace vent pipe in the attic that goes out the roof. Water is leaking from the seams of this pipe when the furnace runs. Roof has been checked and sealed, it isn't the issue. Is this condensation, what can be done to fix it?
  2. cda
    cda Sawhorse
    Oct 19, 2009
    12,717
    567
    When the heater runs
    Or the air conditioner runs??
    What does your a/c heater company say?
    And I guess it happens rain, sun or snow??
    Any certain time of the year?
  3. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,240
    475
    Probably condensation....properly size the flue and seal the joints....
  4. Ty J.
    Ty J. Active Member
    Aug 2, 2017
    25
    7
    Most likely you have the furnace running (heating), which in turn releases some heat via the vent. The warm vent which is in contact with cool and humid Fall air is producing condensate. The condensate then runs down the vent stack and pools at the joints, thus appearing to be the joints leaking.
    If you are worried, Fall is a good time to have you unit serviced - have a local HVAC company come do a preventative maintenance inspection.
  5. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,421
    385
    Propane undergoes combustion reactions in a similar fashion to other alkanes. In the presence of excess oxygen, propane burns to form water and carbon dioxide.
    If it is a propane furnace your problem may be with in the unit itself. Have it serviced since it could be a dirty orifice or other issues.
  6. conarb
    conarb Sawhorse
    Oct 22, 2009
    2,845
    174
    The new high efficiency furnaces expel all kinds of water, but the vents are usually PVC and they have a separate ½" PVC condensate drain that has to go somewhere, the the OP says he has a galvanized vent, there is a possibility that a conventional furnace was replaced with a high efficiency furnace and the galvanized vent wasn't changed.
  7. Ty J.
    Ty J. Active Member
    Aug 2, 2017
    25
    7
    All combustion produces water
  8. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,104
    184
    If this is the case, the duct should be properly sized for the newer equipment. Old equipment lost a lot of heat through the flue, which allowed for the use of larger flues, when replacing with more efficient units, the draw up the flue may not be enough to pull all the combustion gases out, causing them to remain in the flue. Once it cools down the water condenses. This could be a life safety hazard as the gases could be drawn back into the home if the flue or furnace is not sealed properly
  9. Ty J.
    Ty J. Active Member
    Aug 2, 2017
    25
    7
    10yo furnace, see the initial post
  10. cda
    cda Sawhorse
    Oct 19, 2009
    12,717
    567
    Where is Wata our early morning poster
  11. conarb
    conarb Sawhorse
    Oct 22, 2009
    2,845
    174
    I remember getting high efficiency furnaces 15 years ago, so the are older than that.
  12. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    838
    82
    Is it a single-wall pipe or a B-vent (double wall)? Is the furnace atmospheric combustion, induced-draft, or condensing?
    I remember specifying pulse furnaces in the late 70s, and induced-draft furnaces in the 80s.
Share This Page
