Problem or not?
The gas pipe was in a dirt trench and supplied a swimming pool heater. The fitting was crooked and just looked wrong so I asked to have it. There is plenty of confusion inside the fitting but I wonder if it is a big deal or not?
Looking at the joint, there is only heat fusion on part of the joint, and probably why it was cut out. I can not tell what size the pipe is, and am guessing that it was 2psi going to the pool heater. Pressure drop on natural gas, especially if it is only 1/2 psi, could be a problem with a restriction.
I had it removed because it was crooked. You can't see the crooked with just the fitting but in the trench it was apparent at about 30°. That and intuition.
Good call. From the looks of the fitting, they overheated to try and compensate, but what they created is crystallizing the one side, making it brittle, and it would have leaked.
