Forum Coordinator
These are exterior walls but I am thinking this is a more appropriate area to post since it is CMU construction.If you look at the photo you will see that the garage lintel is shimmed up approximately 2" for purposed of making the required R.O.As a result, the block directly above the lintel had to be cut down 2" so it would match up with the rest of the block for the bond beam pour.The issue is that the lintel assembly was specified on the drawings as 32" which is now 30", therefore the construction is not per approved plans. The good news is that this particular lintel is for the only gable on the house and weight is not an issue so the RDP had no problem firing off a letter stating so. There are several other homes with this design that are going to be built and I have thought of 2 fixes. Let me know if you can think of any more:1) Change the prints to show a 30" lintel assembly.2) Change the slope of the garage floor from 1/8" pitch to approximately 1/4" pitch to drop the opening another 2" and we no longer have to look at the cluster around the lintel with the cut and notched block.What say thee?Home built to 170mph wind
/monthly_2013_06/p1803075264-5.jpg.96901e03e63067a9f12e478275c40d73.jpg
