Glennman CBO
Silver Member
- Joined
- Oct 20, 2009
- Messages
- 441
2009 IBC. Apple packing plant at 86,000 sq ft. Originally submitted as an F-1, with contruction type II-A and fully sprinklered in order to get the building area, and fire area covered. There are no area increases for frontage, only sprinklers. Fine. Plans do not show 1 hr rating of primary and secondary frame, including roof construction. The packing plant is just that...packing apples into cardboard boxes, with no "processing".
Now the designer wants to call it an F-2, and reduce the construction type to II-B in order to use the sprinklers only for area increase, because they do not want to rate the primary and secondary frame (roof, etc), and, they have a mezanine closer than 20 ft to the roof.
The non-code commentary has an interp on the classification, as to when you would go from F-2 to F-1. It goes into the thicknesses of the cardboard, basically saying that if the cardboard is compressed paper instead of heavier cardboard typically used for apples, then it must be an F-1. However, if that is the case, then what company does not use corrugated cardboard for packing, say, wine bottles or ceramic dishes? In other words, it would appear that from the commentary's standpoint, almost nothing is an F-2.
One of my plans examiners is saying they agree that it can be an F-2 based on the wording in the code, but the other is leaning toward the commentary calling it an F-1.
I figured I'd get all your fine opinions on this. Thanks.
