Schlage privacy lockset VS. traditional lockset?
n1976jmk
Member
Westfield, NJ
Privacy means it locks (for your bath and bedroom)
Passage means no lock (closets, etc.)
Entry is a keyed lockset
thank you for your response.
I am confused by this item for sale on Amazon.
I am looking for a lockset that can go on our bathroom with a lock on the inside.
I'd like this color combination as well: satin nickle/chrome (for the inside) with a lock on the inside
http://www.amazon.com/Schlage-F40GEO619-Georgian-Privacy-Nickel/dp/B0002YR188/ref=sr_1_1?ie=UTF8&qid=1447351913&sr=8-1&keywords=schlage+georgian+bath+knob
And what confuses me is that the description is listed as 'privacy' and below though it goes to 'traditional' style.
Please help!
n1976jmk said:
thank you for your response.I am confused by this item for sale on Amazon.
Please help!
Good video explains different hardware
https://youtu.be/AFYXgYZucsA
Hi, this video was helpful. Thank you!
But it didn't explain what style 'traditional' meant.
Can you kindly explain that?
Thanks!
Guessing here, but 'traditional' may mean a knob on both sides as opposed to a lever style (which I guess could be considered 'modern')...
Where's LGreene, she's our door and hardware guru...
Yes thanks this is what I need help with.
What does Schlage mean in differences between style 'privacy' and 'traditional'.
Looking forward to that answer
Guess the question also should have been
Residential or commercial, but appears residential
And is this for personal use
Schlage offers two 'styles'; contemporary and traditional. The selector link I posted earlier walks you through the process of selecting the right hardware. Both contemporary and traditional styles come in knob or lever.
Here I am! Schlage calls some designs "traditional" vs. transitional or contemporary but I don't know why Amazon has it listed as passage, privacy, or traditional. Passage and privacy describe different functions (passage = not lockable, privacy = lockable from the inside, can be unlocked from the outside with an emergency tool not a key). There's no lock function called traditional.
I work with the commercial products, not the residential, so if the OP still has questions you can call Schlage Res customer service at 888-805-9837.
Hours of operation:
Monday - Friday 7:30 am to 5:30 pm (Central Time)
Saturday 9:00 am to 3:00 pm (Central Time)
Gang, gang, gang!
Traditional (as in round or knob (and not accessible) (think Baldwin?)) is a design term vs contemporary (as in modern style, lever or other non-knob device (usually accessible without grasping))
As noted by LG, hardware is usually described by function (use/purpose) and style (contemporary/traditional/period, etc.)
ADAguy said:
Gang, gang, gang! Traditional (as in round or knob (and not accessible) (think Baldwin?)) is a design term vs contemporary (as in modern style, lever or other non-knob device (usually accessible without grasping))
Actually Schlage has knobs and levers in both their 'traditional' and their 'contemporary' styles according to their website.
Don't know but two different finished more than likely not
Buy one of each and part them out to make one
Or call Schlage direct and ask
Per Schlage; Traditional style hails from 19th century European design and encompasses the Georgian, Federal and Victorian movements. Careful with these in commercial installations as most levers are straight, lacking an end return to within 1/2" of door face.
Contemporary is modern in appearance, some of these levers may also lack the end return too.
also note that springs in residential levers may not be as strong as in commercial hardware.
