steveray
I've never even seen that required in an IBC firewall situation...And I believe firewall continuity only states "from the foundation.....up"...
This appears to be slab construction, and grade beams would most likely be needed if bearing walls are in play. Maybe the design has all the bearing points from back to front and not using the party walls?
