Hello everyone.
I have a few of questions regarding your inspection of residential, structural wood framing based on call outs on an engineered, stamped set of plans.
If it says on the plan (eg.) "All framing lumber to be SPF #2 or Better" or "All floor framing lumber to be SPF #2" (notice the lack of "Or Better" for floor frame) does this restrict me to using only that?
I feel that "Or Better" means anything above and beyond what's called out. To me, if the engineer calls out an SPF #2 2x12, but experience tells me that I can use a Southern Pine 2x10 then I should be able to use it.
Going beyond that, do I have to go back to the engineer to prove to you that the 2x10 works? Suppose I ask you if the 2x10 meets code. If the member species, spacing and load criteria are in the IRC can you make the decision as to whether it meets code or not?
I hope this doesn't sound like I'm bashing anyone.I'm just curious how you would normally handle this simple change of materials to something other than what was called out on the stamped plans.
Thank you.
Doug
Thank you.
Doug
