Mech
2009 IBC
For calculating the occupant load, I know that the dining area is net floor area and the kitchen and office is gross floor area. What about the restrooms? Am I correct in assuming they are part of the dining area and they do not contribute to the occupant load since the main function of the building is to seat people and feed them, which uses net floor area for occupant load?
While searching on the forum, I saw a post that seemed to indicate the aisle and exit access areas are to be included in the occupant load. How are these areas tallied with a mixture of fixed seating and movable seating? If all the seating is fixed (booths and bar seating), do I assume the aisle and exit access areas provide a zero occupant load?
Thanks in advance.
Thanks in advance.
