jetlag1946
Hi I an going to have 2 garage doors installed on a new construction and want to get the door opener control wires installed in the ceiling before the dry wall is installed . The garage door installer would have to run those across the ceiling if I don't do it now . The ceiling is floor trusses . I want to use a remote control to open the doors from the outside , and also a push button on the wall where the basement door enters garage . What wires need to be installed now in the ceiling ? I tried to find out from the installer but I am still confused what he meant because he keep getting off the subject , and onto the line voltage for the motors . I allready have the ceiling 120 volt recepts roughed in for the door openers
