Ryan Schultz
In order to take advantage of the following, does the garage need to be above grade? Or can it be a below grade garage? The wording is slightly confusing to me.
https://up.codes/viewer/wyoming/ibc-2015/chapter/5/general-building-heights-and-areas#510.4
510.4 Parking Beneath Group R
Where a maximum one story above grade plane Group S-2 parking garage, enclosed or open, or combination thereof, of Type I construction or open of Type IV construction, with grade entrance, is provided under a building of Group R, the number of stories to be used in determining the minimum type of construction shall be measured from the floor above such a parking area. The floor assembly between the parking garage and the Group R above shall comply with the type of construction required for the parking garage and shall also provide a fireresistance rating not less than the mixed occupancy separation required in Section 508.4.
