Tankless Water Heater
Forum Coordinator
Somewhere Too Hot & Humid
If an electric, tankless water heater has a tag showing it is listed by an approved agency with the following information on the label: 240v, 10kw, 42A, what size wire and circuit breaker would be required by code in the absence of manufacturer's installation instructions?
Please don't turn this into a discussion about manufacturer's instructions. This is a legit code question. You have all the information you need.
Spent lunch reading and looking at a bunch of tables...
6 AWG and a 55-amp breaker
We don't have a conductor to carry 45-amps, so we step it up.
I got my head spun around a few times on the breaker sizing, so I've got two reasons (or one 2-part reason) to use a 55 vs a 45:
1) no manufacturer instructions saying a 100% uptime 45-amp is okay
2) 42*125 = 52, so to get a breaker that isn't loaded at more than 80% if the heater runs over 3-hours continuously, we go 55
Some of the reading I was doing mentioned over-sizing the conductor the same way, but I don't know if that is required here...don't have the actual code, just snippets and parts in articles :p
Applying 422(E)(3) suggests a 65 amp is okay (42*1.5=62, step up to a 65), but doesn't that get into potentially enough amperage to overheat the conductor without tripping the breaker?
Still reads to me like the 55 is better- doesn't exceed the 150% max.
Yes, I too am having issues with applying 422.10(E)(3) but it is legit
