Solar array placement Q.
SCBO1
Platinum Member
MID WEST
I have a solar array set-up planned for a flat roof top. The roof top has a large rectangle skylight with the array placement surrounding the skylight.
Q. Is there any code requiring the skylights to be provided a pathway to them. I could see a maintenance issue in my crystal ball in the future where it may be difficult to provide maintenance to the skylights.
I do not believe that there is a code requirement; however, code is not best practice.
There is no requirement. However, how do they plan to access the solar array for maintenance? If one can get to the solar panels, they should be able to get to the skylight, too.
Thanks guys, I know I can't step over the panel due to its width and the service of the back row of panels would be difficult without removing panels. Seems the designer missed this or didn't think it would be an issue?
We did get the clearances around the perimeter, but the inside rows were not provided a pathway for access.
Yep.....No way to access inner panels....I think I even tried to fight access to a plumbing vent at one point that was surrounded...When the panel in the middle craps out, rework the whole system...GREEN BABY!
Designer sez you can walk on the panels:eek:
I have seen that. There is no requirement for access to the interior panels of an array.
The next residential code will not allow solar panels below an EERO. I’m being told that a floor plan will be required at plan check if there is an adjacent wall.
BB,
That is a good find, we have adopted the IFC and I was operating off of common sense, wasn't sure I had a code to back me. Section 605.11.3.3.2 (3.) requires a 4-ft clear pathway to skylights which is the issue at hand. I sent them an email, will see what happens.
Thanks
NFPA is studying lithium ion battery storage There is a video at:
https://www.nfpa.org/News-and-Resea...thium-ion-batteries-hazard-and-use-assessment
NOTE: Not use, Storage of the batteries.
A recent push to include lithium ion battery storage in NFPA 13 prompted this study. It included tests of batteries and comparable general stored commodities in cartons when exposed to an ignition source. Kathleen Almand, the executive director of the Foundation, explains the rationale behind the tests as well as the testing procedures and the encouraging conclusions.
California Supercharges Battery Incentive for Wildfire-Vulnerable Homes
A boosted $1-per-watt incentive will cover nearly the entire cost of a Tesla Powerwall home battery system.
https://www.greentechmedia.com/arti...ergy-storage-incentives-for-wildfire-resilien
September 17, 2019
California has passed its first-ever subsidy aimed specifically at bringing more distributed solar and energy storage to people at highest risk of having their power shut off by utilities trying to prevent wildfires.
The California Public Utilities Commission approved changes (PDF) late last week to the Self-Generation Incentive Program, the state’s premier behind-the-meter battery incentive program. Among them is a $100 million carve-out for vulnerable households and critical services in Tier 2 and Tier 3 “high fire threat districts,” offering incentives that could pay for nearly all of a typical residential battery installation, according to the CPUC analysis.
This supercharged incentive is aimed specifically at people at the highest risk of being hurt if, or when, grid power is cut off for hours or even days at a time under the state’s heightened wildfire prevention regime. While utilities have been sparing in their use of this new "public safety power shutoff" authority so far this summer, they are largely at the mercy of the weather to determine how often they’ll be forced to use it in the future, or how many customers might be affected.
Climate change is driving hotter and drier conditions, putting large swaths of the state at high risk of catastrophic wildfires, including those caused by utility power lines. Pacific Gas & Electric’s bankruptcy was driven by its liabilities from wildfires in 2017 and 2018 caused by its power lines, and Southern California Edison and San Diego Gas & Electric have faced credit downgrades and the threat of insolvency if they’re hit with blame for a major fire.
State regulators and lawmakers have responded to the crisis with steps including a $21 billion wildfire fund for utilities, as well as mandates to invest billions in grid repairs, tree-trimming, weather forecasting, and other wildfire prevention efforts. Thursday’s decision marks the first time the CPUC has approved one of the several proposals from utilities and distributed energy resources vendors such as Sunrun to put market-based incentives to work on the same task.
The funding will come from SGIP’s equity budget, a set-aside for low-income, medically compromised or otherwise disadvantaged residents. Utilities and solar-storage vendors have struggled to enroll many of these customers in what’s still an expensive solar-storage proposition, leaving large portions of the equity budget unspent.
The regulator's decision addresses many of challenges on this front, such as opening SGIP funding to specific Central Valley disadvantaged communities and participants in existing multi-family housing solar programs. It also boosts the current cap of 50 cents per watt-hour for battery installations, already higher than the mainstream incentive, to 85 cents per watt-hour.
Higher premium
The $100 million carve-out would apply an even higher premium to systems meant to bolster grid resilience against wildfires, up to $1 per watt-hour. “This will address the primary barrier to participation in SGIP by equity budget-eligible customers, particularly residential customers, which is lack of access to financing or capital,” the CPUC noted.
Indeed, at $1 per watt-hour, SGIP pays for $13,200, or 98 percent, of the cost of the typical Tesla Powerwall residential battery system used as the CPUC’s reference case, compared to $6,600 or 50 percent at 50 cents per watt-hour, or $11,200, or 83 percent, at 85 cents per watt-hour.
“Party comments on the proposed decision persuaded us that the risk of setting the incentive levels too low for the new equity resiliency budget and the equity budget, leading again to no or very low participation in these budgets, outweighs the risk that developers will inflate costs,” the CPUC wrote.
Not everyone living in Tier 2 or 3 areas will be eligible for this funding, only “SGIP critical resiliency needs” customers. With a few exceptions, this includes people who meet the equity budget’s low-income and disadvantaged criteria, or are “medical baseline” customers who have notified their utility of a “serious illness or condition that could become life-threatening if electricity is disconnected.”
Critical services and critical infrastructure in Tier 2 and 3 districts can also apply for the carve-out, although CPUC’s decision makes clear it will prioritize “only the most critical facilities and infrastructure and those with the least ability to fund a storage system.”
The CPUC also set up new rules for critical resilience customers, who are meant to use their batteries to “island,” or run disconnected, from the grid, to deal with the fact that the SGIP program wasn’t designed for islanding. These include requirements to have the system inspected by the local utility or another authority with jurisdiction over its interconnection, and to file data on how long it can operate in island mode under different conditions.
Beyond the $100 million wildfire carve-out, the decision makes some important changes to SGIP’s approach to low-income, disadvantaged and multifamily housing, the CPUC’s press release noted. Those include granting eligibility to participants in the Single Family Affordable Solar Homes (SASH) program, the SASH for Disadvantaged Communities program, the Solar on Multifamily Affordable Housing program, and the Multifamily Affordable Solar Housing program.
The CPUC also approved $4 million for heat pump water incentives and $10 million for SGIP storage incentives to support pilot projects in 11 San Joaquin Valley disadvantaged communities.
Easy access:
Mark, we were told that SCE won't allow bypass feeds to residences from onsite solar in the event of an area wide power failure as if they continue to feed into the grid it causes issues.
Where did I use the term "Bypss feed"?
Grid tied PV inverters shut down if the utility power is cut. Placing a main breaker in the off position stops the output from a grid tied inverter.
BB,
Thanks
This is the strength of the Forum, We all have different levels of exposure to different codes. Although I am a MCP, I would never claim to be a plumber, electrician, Mechanical Contractor, or even a decent builder/framer. I am an old firefighter who has had the opportunity in thirty years to bounce back and forth across the fence of being in various building departments and Fire Departments - 4 fire departments and 3 building departments - I know and have seen the results of short cuts and have spent some time in the hospital for poor construction oversight and contractors that took short cuts.......
The point is that I also use this board to perform research and ask questions all the time - the best question that was answered by an very informed person on this board involved the question of how out of plumb could compression posts be and still be accepted. Truth of the matter, when you think you know the code - That is when you are going to be proven wrong.
