gnarkill283
This might be less of a code question and more of a roof design question but since everyone's so helpful here, I thought I'd ask it anyway. We have a large roof that will only be accessible by maintenance personnel. We are trying to keep the parapet heights as low as possible so we are going with the minimum 1/8" per 1' slope to drains if possible. The roof construction is roofing membrane on top of sloped polystyrene boards on top of concrete/metal deck. I'm new to modeling drainage roofs in Revit and what I've noticed when you actually have to model these slopes is that the longest distance to drain decides the edge height of all the drain areas. That's because if say one drain area is smaller than another, it still needs to reach the same height so there isn't a tripping hazard between the 2 areas right? Also should I be using crickets to reduce insulation costs? Its impossible to model crickets accurately in Revit so in some projects I've seen just slopes indicated with line work and no spot elevations (I'm told that the roofers will know how to slope the crickets themselves). Appreciate any help - thanks
