TheCommish
Does anyone know of a code or regulation that would requis air smoke damaged soot s stained building components or installation to be cleaned removed or encapsulated
Not it….Does anyone know of a code or regulation that would requis air smoke damaged soot s stained building components or installation to be cleaned removed or encapsulated
[A] 114.6 Restoration or abatement.
The structure or equipment determined to be unsafe by the fire code official is permitted to be restored to a safe condition. The owner, the owner’s authorized agent, operator or occupant of a structure, premises or equipment deemed unsafe by the fire code official shall abate or cause to be abated or corrected such unsafe conditions either by repair, rehabilitation, demolition or other approved corrective action. To the extent that repairs, alterations or additions are made or a change of occupancy occurs during the restoration of the structure, such repairs, alterations, additions or change of occupancy shall comply with the requirements of Section 105.1.5 and the International Existing Building Code.
How is IFC 114.6 related to the question? It says nothing about smoke damage. It calls for abatement when (if) the fire code official (not the building official) determines that a structure or a piece of equipment is unsafe.
The IFC doesn't define "unsafe" (or "safe," for that matter). Neither does the IBC. It's unlikely that a fire code official would cite smoke stains as an unsafe condition, so where does that leave you?
[A] 115.1.1 Unsafe conditions.
Clearly, the conditions of repairs, vapor barriers etc., would need to meet current building codes when repairs are made.
Your position on soot and smoke stains from a structure fire is that they are merely cosmetic and safe?You keep citing code sections without the code language or explaining how they might apply.
The question was about smoke damage and soot stains. There's no mention of smoke damage or soot stains in IFC 115.1.1. Smoke damage and soot stains are cosmetic issues, not unsafe conditions as addressed by 115.1.1
So
They do not present a hazard to human life and do not require abatement?
The soot that can be produced from a structure fire can be rather toxic to humans, and the type of material burned in the structure dictates how dangerous the abatement will be. VOC, heavy metals, formaldehyde etc., are hazardous and require the correct disposal to be set in place.Yes, that's my opinion. But the only opinion that counts is the opinion of the fire code official in the jurisdiction of the location of the structure in question. It was my understanding that TheCommish (the OP who posed the question) is a building official, not a fire marshal. If that's correct, he doesn't enforce the IFC (if it's even adopted in Massachusetts), so whether smoke stains will require abatement under the IFC would be determined by the fire code official in the jurisdiction.
IFC section 115.1.1 doesn't just say unsafe conditions have to be abated or repaired, it specifies WHICH conditions may be unsafe and require abatement:
I have never heard of soot or smoke damage being deemed dangerous to human life. YMMV.
- Inadequate means of egress
- Inadequate light and ventilation
- Constitute a fire hazard
- Are otherwise dangerous to human life or public welfare
There is actually an ANSI standard ANSI/II CRC S 700 that was created for this very type scenario. It has not been adopted by OSHA yet, so at this point, it is not technically enforceable by AHJ, but it is the works.
Does anyone know of a code or regulation that would requis [require] air smoke damaged soot s stained building components or installation to be cleaned removed or encapsulated
