When do we blow CC foam in the walls...
cw24
NY
Insulation contractor suggested we blow 2" of CC foam before we rough the electricity and plumbing, then come back and blow the rest of the 5" CC foam called for by HERS rater after. Why would he suggest this and is he right?
My first post so thanks in advance!
So he can get the rough-in in the middle of the wall cavity. But that means an extra trip for him, and working him into the schedule. But the liquid spray goes around the wires and pipes and fills in nicely. Not sure i see his logic.
7" of closed-cell foam. 2x8 studs or a double wall? That's about R-46 cavity insulation. Or is it open-cell or batts going in later? Just curious. Sounds really expensive using that much closed-cell. Is there continuous on the outside?
I know Im late to this, but If he fills the cavities with closed cell none of the trades will be happy. I can imagine trying to add channels for every pipe or wiring chase in a new build. There are plenty of foamed homes in my area, and I don't believe I ever saw foam go in until after all of the roughs were done... I don't know everything, love to learn and Id be curious as to why the installer wanted to get a head start.
