Accessible kitchen faucet sprayer?
Yikes
Southern California
ADA / 11B-606.4 requires that kitchen faucets comply with 309 (no tight grasping, pinching, or twisting of the wrist).
But does this also apply to a handheld sprayer accessory? Is the accessory considered a type of "faucet"?
Examples:
1. A sink is supplied with both an accessible faucet and a second, separate handheld sprayer wand. You grasp and pull the wand/handle to make the nozzle point into the sink, and you grasp / press the button on the wand to make the water come out.
The sprayer is also located towards the rear of the sink (check reach depth vs. waste disposal obstruction below).
Question: if the main faucet complies, must the accessory wand also comply? ADA/11B-212.3 only requires 5% of each type of sink to be accessible. Does that imply that only 5% of water-emitting devices at a sink need to be accessible?
2. In this scenario, the wand is integral to the main faucet spout, but it has a button selector for different spray controls. Still requires grasping and pinching to fully depress the button:
My opinion on this is that, because the sprayer is part of the kitchen sink, the sprayer must meet the same accessibility requirements as the main faucet.
No, it’s an accessory to a kitchen sink and the kitchen sink is one plumbing fixture. The sprayer doesn’t have controls to regulate the water temperature or pressure, it needs the main faucet. Kind of like a handheld shower sprayer, you have a fixed spray head up high and one down low in a cradle, but all together it’s one plumbing fixture.
I think it should because I am considering the sprayer as a part of the entire kitchen sink plumbing fixture and if part of the plumbing fixture doesn’t comply, the fixture is not accessible.
Is the kitchen sprayer button that much different than an elevator button or the buttons on the front of a vending machine? I’d say it’s OK.
There are faucets where the nozzle sets into a rigid sleeve that enables it to function with the push of a button, no grasping required:
There are other nozzles that do not retract into a rigid, but instead permanently dangle down. These are loose, and require grasping in order for the button to depress. Is it "tight" grasping? I don't know. But if I had no opposable digits, I couldn't change the spray control:
Even with this you still might need to grip it. Here’s the kitchen faucet with a pull-out sprayer I have at home:
There’s a black button on each side, it runs through the width of the sprayer so when one side is pushed it pushes the other side out. Buttons are relatively large and easy to push, but the trick is that you have to hold the faucet in place by gripping it between your thumb and fingers, otherwise when you try to push one of the buttons it rotates the neck of the faucet instead of pushing the button in. So if you want to eliminate any grasping you keep pushing until it reaches the limit of travel. Having used this faucet for years I would say it is not accessible because sometimes it requires tight grasping to pull it out because of a design flaw where the O-rings around the base of the sprayer sometimes roll out of their tracks a little and it binds and you have to pull much harder to remove it.
Good question. No grasping is required to point it at an angle, but it’s definitely going to flex when you try to push the button so you have to grasp it enough to prevent it from moving. If we’re allowed up to 5 pounds force for an operable part then 5 pounds would be the limit for “tight” grasping I would think, otherwise “tight” is a little subjective.
Examples:
Hello Yikes!
Do you have a side view elevation showing the distance from the leading edge of the counter to the faucet handle at the position with the handle pushed as far back as it will go? I am attaching a standard ADA sink side view and plan view with disposal. It was reviewed by Josh Schorr of the US Access Board meeting the minimum requirements for a kitchen sink. The sink and faucets specs are called out. So far this aspect of maximum reach, has been ignored by manufacturers. This is for forward approach.
THANK YOU. :) I WANT TO BE SURE YOU NOTICED THAT I NEEDED TO MOUNT THE SHUT OFF VALVE OFF TO THE SIDE OF THE SINK. JOSH SCHORR OF THE US ACCESS BOARD SAID THAT IS THE WAY IT HAS TO BE. TYPICALLY, THE REACH TO THE VALVE ON THE FAUCET HEADS ARE ALL OUT OF ADA COMPLIANCE UNLESS YOU INSTALL A VERY NARROW SINK TO BRING THE FAUCET HANDLE WITHIN 19 INCHES FROM THE FACE OF THE COUNTERS LEADING EDGE.
My client did a mockup with an Elkay sink, In-Sink-Erator disposal, and Cleveland Faucet Group (Moen brand?) faucet with integral handle, and got the reach ranges to work with about 1/16" to spare!
This particular valve handle only rotates 45 degrees to right/cold and 45 to left/hot, so in all positions it stays within reach range.
I have other clients who like the Moen Lite disposal because it is only 5 3/8" diameter x 13 3/8" long.
The 19" dimension is not fixed; it primarily depends on the knee and toe clearance under the sink. The key consideration here is that individuals using a wheelchair cannot reach or operate the controls located past their toes. Therefore, the more you can set the sloped ADA valance or drain piping back from the leading edge of the sink, the greater the depth of the knee / toe clearance will be from the leading edge of the sink. This clearance / reach can extend up to a maximum of 25" from the leading edge of the sink / counter. But this is all dependent of the plumbing configuration under the sink.
Reach range is the easiest thing to comply with. The operation of the item in question is much more challenging, how many faucets or sprayers are operable without some form of grasping or pinching (squeezing)? I have a combo faucet/sprayer in my kitchen at home and the operation is via a rocker button, but you need to squeeze the faucet head to actuate the rocker button - fingers on back, thumb in front - ADA fail.
