Welcome to the new and improved Building Code Forum. We appreciate you being here and hope that you are getting the information that you need concerning all codes of the building trades. This is a free forum to the public due to the generosity of the Sawhorses, Corporate Supporters and Supporters who have upgraded their accounts. If you would like to have improved access to the forum please upgrade to Sawhorse by first logging in then clicking here: Upgrades
Yes an egress door leading to the exterior. And yes the sleeping rooms have windows. Most two-story R-2’s have a front and rear exit, but from time to time that only have the one. Then there are the buildings that were converted from a two-unit into a four-unit by splitting each level into 2. Unfortunately a lot of time this is done without a permit or approval.
NY Building Code Table 1006.3.3(1) allows a single exit if there are no more than 4 dwelling units per story and a maximum travel distance of 125 ft. (from the farthest point inside the dwelling unit to where the stairs discharge). However, it also requires all R occupancies to be sprinklered and have emergency egress and rescue openings.
ICC Digital Codes is the largest provider of model codes, custom codes and standards used worldwide to construct safe, sustainable, affordable and resilient structures.
codes.iccsafe.org
I'm not sure how the Existing Building Code would treat this; it would depend on the type and extent of alterations.
