    Dismiss Notice
1970 BOCA basic building code - stairs
Discussion in 'Existing Buildings Codes' started by fisher, Nov 3, 2019.
  1. fisher
    fisher Registered User
    Nov 3, 2019
    1
    0
    Need to establish requirements for stairs (means of egress) in 1974 and think that would be as in 1970 BOCA Basic Building Code. Can anyone point me in the right direction or have a copy that they could scan and forward to me? Thanks.
  2. cda
    cda Sawhorse
    Oct 19, 2009
    16,921
    1,102
    Welcome
    There are some old timers and also code book collectors
    Might be sometime Monday or after.
    Can you be more specific what you need???
    when required?
    size ?
    tread?
    Or other question?
  3. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    4,002
    384
    Type of building, number of stories?
    Existing condition you are concerned about?
  4. rogerpa
    rogerpa Silver Member
    Nov 5, 2009
    239
    46
    1975 BOCA unchanged from 1972 BOCA. I don't have anything earlier.
    SECTION 616.0 INTERIOR EXITWAY STAIRWAYS
    616.1 Capacity: The capacity of stairways and doors per unit of exit
    width shall be computed in accordance with Section 608.0. .
    616.2 Minimum dimensions
    616.2.1 Width: All interior exit way stairways shall be not less than
    forty-four (44) inches in width, except that such width may be reduced
    to thirty-six (36) inches in buildings of single exit construction when permitted by Section 609.3.
    616.2.2 Headroom: The minimum headroom in all parts of the stair
    enclosure shall be not less than SIX and two-thirds (6-2/3) feet.
    616.2.3 Restrictions: stairways shall not reduce in width in the direction of exit travel.
    616.3 Landings and platforms
    616.3.1 Width: The least .dimension of landings and platforms shall be
    not less than the width of stairway.
    616.3.2 Vertical rise: In buildings of use group A (assembly) and use
    group I (institutional) occupancy, the height of vertical rise shall not
    exceed nine (9) feet between landings and intermediate platforms. In all
    other buildings, a stairway shall not have a height of rise of more than
    twelve (12) feet between landings.
    616.4 Treads and risen
    616.4.1 Minimum dimensions: The height of risers and width of treads
    in inches shall be as indicated m the following Table 616.
    Table 616
    TREAD AND RISER SIZE
    Use group Maximum riser Minimum tread*
    Assembly and institutional 7-1/2" 10"
    All others ~ 8" 9"
    *All treads shall have a nosing or effective projection of 1". There shall not be a variation exceeding 3/16" in the height of risers.
    616.4.2 Winders: Winders shall not be permitted in required exitway stairs, except that in one- and two-family dwellings and in ornamental stairways not required as an element of an exitway, treads with a minimum width of four (4) inches and an average width of nine (9) inches may be permitted.
  5. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,782
    964
    Specific question would help....
  6. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    4,002
    384
    Welcome Fisher
    Specific reason for you inquiry? Did you fall? What type of building?
  7. cda
    cda Sawhorse
    Oct 19, 2009
    16,921
    1,102
    I think Fisher gave up???
Share This Page
