Accessibility: Do Your State Accessibility Requirements Read the Same?
Forum Coordinator
Somewhere Too Hot & Humid
101.2 Effect on Removal of Barriers in Existing Facilities.​
Removal of architectural barriers, pursuant to 28 C.F.R. s. 36.304, from buildings, structures or facilities shall comply with this code’s requirements for alterations unless compliance would render the removal not readily achievable. In no instance shall the removal of an architectural barrier create a significant risk to the health or safety of an individual with a disability or others.
This code applies to alterations to existing facilities that are subject to the barrier removal requirement under Title III of the ADA to the extent required by regulations issued by the Department of Justice incorporated in 202.6.1 and to alterations undertaken by Title II entities to provide program access.
This document does not address existing facilities unless altered at the discretion of a covered entity. The Department of Justice has authority over existing facilities that are subject to the requirement for removal of barriers under Title III of the ADA. Any determination that this document applies to existing facilities subject to the barrier removal requirement is solely within the discretion of the Department of Justice and is effective only to the extent required by regulations issued by the Department of Justice.
24.301.902 DISCLAIMER
(1) A building permit or certificate of occupancy issued by the state or a municipality or county must contain a statement that reads: "Compliance with the requirements of the state building code for physical accessibility to persons with disabilities does not necessarily guarantee compliance with the Americans with Disabilities Act of 1990, the Rehabilitation Act of 1973, the Fair Housing Amendments Act of 1988, Title 49, chapter 2, commonly known as the Montana Human Rights Act or other similar federal, state or local laws that mandate accessibility to commercial construction or multifamily housing."
