ameliasolis
By a stroke of good fortune, I've just acquired a nearly new very high pressure airless paint spraying rig, complete with gun, pump, hoses etc. According to the (rather basic) instructions, it looks to be fairly easy to use, but I've zero experience with this sort of spray kit; all I've used in the past is conventional spray guns and HVLP.
I've had a look around YouTube, and there seem to be loads of American videos on spraying house interiors, but all the ones I've seen are a bit thin on detail. It seems that this method of painting is common in the US, but not used as much here.
I want to use this to paint the inside of our garage with white emulsion, as it looks as if using a high pressure (as in around 200 to 250 bar) sprayer is a very quick way of covering a fairly large area. Has anyone here used one of these things, and if so, are there any words of wisdom that could be shared?
