bill1952
Even in in a dimly lit smoke filled environment?easy to tell which are exits and which are not.
IF...that is a problem, maybe we need brighter exit signs or more floor proximity signs.....Even in in a dimly lit smoke filled environment?
Thank you for this, remember if it looks like a door it must comply with ADAakelly, welcome to the forum!
It really helps is you tell us (1) where the project is located, so we know which code/jurisdiction is applicable, and (2) whether it is (a) new, (b) existing with no changes, or (c) existing with an addition or alteration proposed.
If you have a space that requires 2 exit doors but has 12 exit doors, then only 2 doors need to be made "code compliant" with the provisions IBC chapter 10 'Means Of Egress'. You certainly would not have exit signs on the other 10 doors if you don't intend to use them for exiting.
Since this was posted in the Accessibility forum, perhaps you meant to ask, "do the other 10 convenience doors in excess of those required by CBC chapter 10 need to be made mobility accessible per CBC chapter 11B?"
Assuming it is in Sacramento or somewhere in California, CBC 11B-206.4.1 for new buildings has a couple of exceptions:
ADA is a separate but related issue that you will want to consider as well. It will not be enforced by your city building official.
ADA Standard 206.4.1 says:
Let us know if your building is existing - - there may be a different response for existing vs. new.
ADAguy, please provide a code or regulatory reference that backs up this statement.remember if it looks like a door it must comply with ADA
So an overhead door?Thank you for this, remember if it looks like a door it must comply with ADA
It may be in the civil rights act we call ADA which I never read or enforce as an inspector, but this is not in the IBCremember if it looks like a door it must comply with ADA
if "not a signed exit", it is "still a door"; must not a door still comply with the requirements for a door; as to: min/max size, manuvering approach, hardware?I generally agree TMurray, but having been on design team on projects in many jurisdictions, the answer to the OPs question "Do you find in some jurisdictions that you are required to make all of those doors code compliant exits?" remains yes.
I guess if you only work in one or a relatively few jurisdictions, not much of an issue. You learn or decide what the interpretation is.
A door is a door with an intended purpose, to enter an exit a space (unless excepted). Code sets minimums in Chapter 11b & 10) for them, exclusive of whether they are egress or not. Ask an insurance company if they will deny coverage for excessive doors that don't comply?bill1952, I provided one code and one ADA citation in post #5 showing where not all exit doors are required to be accessible to persons with disabilities. If you have an alternate citation, please provide it.
Example:A door is a door with an intended purpose, to enter an exit a space (unless excepted). Code sets minimums in Chapter 11b & 10) for them, exclusive of whether they are egress or not. Ask an insurance company if they will deny coverage for excessive doors that don't comply?
Depenes if they are entrance doors or exit doors or both. only 60% of entrance doors need to be accessible entrances and only 2 exit doors are requred to be accessible means of egresso this started with a warehouse with 12 doors, but only 2 required. I sense the consensus here is that the 10 not required doors don't have to meet any requirements (except perhaps fire resistance). So are 60% of the 2 (both) or the 12 (8) required to be accessible?
