Aw S??t, ..wonder what went wrong here?
Love when a building with a fire sprinkler system burns to the ground,,,,
Maybe did not get an upgrade for the hazard????
Fire Chief Jim Topoleski told Fox 11 that in addition to determining the cause, the investigation will look into how such a large fire occurred in a modern building with the latest in fire protection systems.
“Something overwhelmed the sprinkler system immediately to allow the fire to rapidly grow," he said.
https://abcnews.go.com/US/wireStory...n-california-warehouse-linked-amazon-71096230
In situations such as these you work out to in such as system(s) certification and testing records verification and review, since there could have been up to 50 or more sprinkler system types in many combinations in this type of facility. Water supply, pump failures, obstructed/closed valves and supervision, interior loss prevention personnel human error (testing and maintenance) are all typical starting points.
In these super sized facilities it takes months to get the bugs and supervisory wiring gremlins in integrated fire alarm controls and fire sprinkler interlocking worked out due to the vast spanning of sub-control and communications and panels. Even while occupancy permissions have been granted. It also takes that long or longer for the facility’s loss prevention staff to understand the systems and be confident in their own inspection, maintenance operations and testing.
AHJ’s have to stay on top of it because in real life, the facilities are approved for occupancy and operation in phases. That’s just the way it is.
It is also not un-common to see a facility have hundreds of false alarms after systems are commissioned due to building situations and after occupancy equipment relocations affecting supervisory equipment and creating gremlins. It is critical for facility loss prevention teams and FD staffing to not become complacent and understand the nature of these mega structures and develop plans to address the situations.
I’m happy to read that everyone got out and there were no injuries since it is not uncommon for these facilities to have zoned evacuation and notifications.
Time will reveal the causes/failures, there should be some interesting lessons learned. We will keep you updated on this.
Thanks, ADA!
I do miss (some) of the investigation work but not the 2 am jobs when its -10 and winds at 25 mph. There will be a lot of folks involved in this one and hopefully there is a good lead and they can all play in the sandbox together and be productive.
Smart arsonist....close valve start fire not a good combination. Will be interesting if they tell us but I wonder if the had PIV to the pump house or risers with only a lock to prevent the valve from being closed.
FDC= fire department connection down stream of all valves in a wet system, should always be supplied with water to over come closed valves
Yes and No
Depends on set up
Plus fdc is not designed to be the main supply to a system
Even with all of the destruction, it should be easy to determine if any valves had been closed. It won’t be like an airplane wreck where you are looking for small clues, valves for tgis size building will be easy to find and easy to see what position they were in.
Maybe
Depends on which way the tilt wall fell.
I think all the cameras, and employees will be able to see the progression
Amazon said the facility was used to ship large products such as mattresses
My guess system was not upgraded for the foam mattresses of today
Products of combustion vs ignition source ='s speed of consumption. Here in lies the question, without sprinklers how and why could it have moved so fast? Spontaneous combustion?
Fires don’t move fast, except wildland
Fires doubles about every minute
Possibly rack storage of bad stuff, that likes to burn.
Depends on what you mean by moving fast...I think the Ballys Casino fire it took off across the carpet at 20FPS....Faster than I want to run from fire....
The fire spread to the lobby, fed by wallpaper, PVC piping, glue, and plastic mirrors, racing through the casino floor at a speed of 15–19 ft/s (4.6–5.8 m/s; 10–13 mph; 16–21 km/h) until a massive fireball blew out the main entrance along The Strip. From the time the fire was noticed, it took six minutes for the entire building to be fully engulfed.[6] It spread across the areas of the casino in which no fire sprinklers were installed. Eighteen people died in the casino level of the hotel.[7]
