Hoping someone can clarify an issue with a townhouse that I am renting. In addition to the garage, the house has two exterior doors -- a street-level front door and a basement-level back door that leads to a back patio. The back patio does not open directly to a public way, but you can eventually get to the street if you cut across my neighbors' patios and then around the side of their homes.
My front door was damaged by someone who tried to break in, and it had to be boarded up. That was three weeks ago, and the landlord still can't tell me exactly when it will be repaired -- so, for now, I have to use the garage to enter and leave.
I see in R311.1 of the IRC, an egress door is required to "open directly into a public way or to a yard or court that opens to a public way." Here's my question - does the basement back door meet this requirement, since you can eventually reach the street from the back patio? The stairs leading to the basement and the landings seem to meet the requirements. I was going to call the county building inspector, but then I found this forum and thought maybe someone could shed a little light on this.
Irrespective of whether it meets code, is this a serious safety issue, and should I even be staying here? If the garage door opener isn't working, I can't reach the manual release without a ladder or stool. And I'm thinking that it could be difficult for EMTs or other first responders to get inside in the event of an emergency.
If anyone has thoughts on this, I'd greatly appreciate it - thanks!
