2015 IBC, Table 602, 4-story building with ground floor retail and 3 stories of apartments above.
Rectangular building with two opposite side walls right on the property lines, and the front and rear walls have more than 30' separation. First floor is Mercantile use, so 2 hour rated side walls at property line. Levels 2-4 are Residential use, so 1 hour rated side walls at property line.
Question: Does the fire rating of the side walls need to wrap around the corners to the front and rear walls for some specified distance? My coworker has suggested they do but I don't see any such requirement in the code.
