    Dismiss Notice
    Dismiss Notice
Does a waste line connecting to sewer line have to be underground?
Discussion in 'Plumbing Codes' started by SJP415, Aug 19, 2018.
  1. SJP415
    SJP415 Registered User
    Jun 15, 2017
    11
    1
    Hi all - we are about to start a project where we are converting our detached garage into a mother-in-law unit and adding a new bathroom with a shower, sink and toilet in it. The new bathroom will need to connect to the main sewer line and have a waste line/drain line (not sure what the right terminology is here sorry - I'm talking about the new pipe line that connects the new toilet to the main sewer line). The question is does this new line that will connect to the main sewer line have to be buried underground? We have gotten conflicting information from two plumbers: one said no it can just run under our deck as long as it has the right slope and it's not exposed to the sun; the other said it had to be underground and we would have to dig a trench. We live in San Diego so no frost worries here. It would cost a lot more to have to put it underground so just wondering if anyone knows if there is a code requirement that says it has to go underground? We can easily hide it under our deck to keep it away from sun exposure. Thank you!
  2. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    9,938
    642
    It needs to be protected, and uniformity supported. It also needs to have accessable cleanouts and have proper slope.
    #2 mark handler, Aug 19, 2018
  3. cda
    cda Sawhorse
    Oct 19, 2009
    15,598
    948
    Interesting no burial required?
    Try an anonymous call to the city to check also.
    JBI likes this.
  4. ICE
    ICE Sawhorse
    7,975
    795
    On the topic of protection: I was told that the only ABS that is allowed to be exposed to sunlight is that bit above the roof. That bit must be painted. All other, including cleanouts, is not allowed to be exposed to sunlight with or without paint.
    That was at a ICC accredited training class. When I questioned that I was informed that the manufacturer's installation instructions require it.
    Then I found this:
    312.13 Exposed ABS Piping. ABS piping shall not be exposed to direct sunlight.
    Exception: ABS piping exposed to sunlight that is protected by water based synthetic latex paints.
    #4 ICE, Aug 19, 2018
  5. north star
    north star Sawhorse
    Oct 19, 2009
    3,671
    226
    Maybe we should clarify exactly what type of pipe
    **SJP415** is referring to.......ABS, ...PVC,
    or something else.
    Also, ...the 2016 CPC, Section 312.3 requires a minimum of
    12 inches depth of the building sewer.
    JBI likes this.
  6. mark handler
    Oct 25, 2009
    9,938
    642
    That section says "..materials other than those approved for use ..."
    If the material are approved, they donot need to be 12-inches below.
    How many raised floor houses havd you seen with the sewer line strapped to the underside of the joists, not buried 12-inches below grade.
    Most sewer under slabs or in structures are not 12 to 24 inches below the slab..
    #6 mark handler, Aug 20, 2018
  7. north star
    north star Sawhorse
    Oct 19, 2009
    3,671
    226
    Thank you for the correction Mark ! ;)
  8. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    804
    103
    Charolette Pipe allows non pressure schedule 40 PVC to be installed exposed to direct sunlight if the pipe covered with water based latex paint
  9. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,778
    282
    Within the building it is a building drain NOT a building sewer line... the building drain is not exposed to direct sunlight.
    mark handler likes this.
  10. mark handler
    Oct 25, 2009
    9,938
    642
    Read the original post
    Same thing, it does not need to be underground.
    JBI likes this.
  11. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,778
    282
    mark, we can agree to disagree I suppose...
Share This Page
