Luis Almeida
Does anyone know if there is an issue in egress path to travel up one story (in rated enclosed stairway) from a roof terrace to reach the fire exist stair down and out of R2 building in NYC? Thanks!
There is nothing that says an exit can't go up....(underground buildings or basement egress)...so there is nothing that says it can't go up and down...Once you are in the exit, travel distance stops, so it could be several hundred feet long of up and down and it COULD be compliant....Building it correctly, especially in retrofit, may prove difficult.
Is the exit required
If this is one unit of an apartment building and tenant controls who has access??
I would think so as it seems like a really big space, but that is where to start really, I was assuming it was required.
